does anyone know exactly what wire i splice for my ignition disabler on the scorpio alarms. A pic would be awesome as well thanks. I have on '05
if I remember correctly its the brown with white stripes. Look at the fuse under the seat, labeled IGN for ignition is what you want. flip it over so you see the wire. trace it down cut and connect. simple. before you hook it up try to start the bike with this wire cut. it should not crank. Good Luck.
yeah i got it all set up, i didn't realize that the whole fuse box lifts out so easily. Once i figured that out it was very simple. Thanks though.
