wel it's winter here and i have about a week of free time due to the holidays
right now tring to determine things i need to do to work on the bike
no particualr order
install jetkit
synch crabs
clean carbs
replace spark plugs
check valve and replace etcc
coolant change etc
change brake fluid
anything else i am forgetting?? i'm at workj and trying ot come up with a list or otherwise i'd look at my manual
The bike has 10k on it..it's a 2000
Just want to do some stuff inthe garage away from visiting family...ughhhhhh
Are you in the process of winterizing it or what? I am guessing that is what you are doing so don't forget to either drain the gas tank or stabilize a full tank of gas, pull the battery and let some air out of the tires.
Do a search on 'winterizing' and you will come up with plenty to read.
clean carbs, install jet kit, synch carbs...the rest you can do whenever
BTW, how do you synch your carbs and how do you know if they're off?
is it the cam timing you can change to get more hp or change where you get your hp?
By using a set of vacuum gauges. A lot of accessory dealers sell them in a bank of four. It's then a case of connecting the attached hoses to the carbs and balancing them against manufacturers spec.
where is ambler pa?
