It would be great if someone could shed some light on what would cause wear patterns like this on my front tire...just a side note, when I purchased the tires the rear turned out to be defective...I'm just assuming that the front tire may also have been defective? The front tire pressure is set to 32 psi. There is and has always been a slight wobbling between 40-45mph. Stem bearing is tight...could it be that my forks are out of wack?
Thanks in advance
Thanks in advance
