I know it has been sorta discussed but I never saw the real answer to this question. Pulling up in second gear. I know it can be done using clutch but my main question is this. do you
a. roll up first, shift to second, roll up a little, let off the gas while pulling in the clutch, roll up the throttle and dump the clutch
or
b. roll up first, pull in the clutch, shift to second, rull up the throttle then dump the clutch
or
c. roll up first, pull in clutch, shift to second, drop clutch, roll throttle then while on the gas pull in the clutch roll more throttle and then dump the clutch.
I know i'm making it seem harder than it is but I gotta know.
or
or
