You can use the same oil filter that fits on the 2000-2002 model ZX-6R's for you 2003 model. The only diffrence is the length over all, granted it carries a few CC's more in capacity, adding four quarts should be fine since I doubt you'll be removing the heat exchanger and getting ride of that small amount of oil either. Hope this helps!
Chaos, panic, disorder......
my work here is done
