I work as a technician full time on german cars, so I guess you can say im handy with tools. This would be my first time changing the fork seals and springs, so hopefully it stays "simple"
Basically, Ill be buying .95 kg/mm springs, and both fork seals. Is there anything else I should buy for something like this? Also, what weight oil should I use for the forks? Mine have been leaking for a while so ill be needing to add oil.
If im upgrading the front spring, I should do something about the rear spring as well... any suggestions on where to find one? Thanks again for the advice, Ive been working on cars for 15 years but im clueless on bikes.
