Quick background info:
This is my wife's bike. It's an 07 (I think? Last year they made the older style), has very low miles (less than 1,000), always garage kept, (usually) drained of fuel from the carbs for long storage, and nothing is modified or changed from stock. Last year it sat all winter with the pet cock on(whoops, my bad!). It started right up the following spring but during the first ride it started loosing power as she described it. It wasn't working properly and then just went bad quickly - it gradually got worse and worse until it was un-ridable and in it's current condition.
Problem:
The choke needs to be on fully for it to idle. After it gets warmed up it can be moved to about 75% and still idle. Moving it much further than that it will just stall out. Even with the choke on fully, slightly tapping the throttle just bogs it down. If you hold it to try and get some RPMs, it just drops down and stalls. When it's in gear it is possible to get it to move... although it has to be done by letting the clutch out really slow and giving no throttle. Giving throttle and releasing the clutch like usual results in a stall every time.
Video of the problem:
Solutions I've tried so far:
Changed the gas in the tank and ran it long enough to cycle the fuel in the carbs.
Diagnosis:
I suspect something with the carbs. I intend to take them off and clean them out pretty good. But my question is - where should I pay most attention while cleaning? Is this obviously something else?
Any advice or tips will be greatly appreciated!
Problem:
Diagnosis:
