1 - 9 of 9 Posts
I like my 6R just fine with the stock screen, but I want a little extra wind protection. I plan to take longer trips over the summer, so it would be nice if I could relax a bit.
Are there any windshields for zx6r J that are not just for looks?
ZX6R-J1 2000
Zero Gravity Double Bubble makes a big difference on the two bikes I've ridden with them... the 6R and the R6. And once you get used to the different profile to the bike, I actually think they look pretty trick too.
I put on a Lockhart Phillips Speedscreen V2, which is basically the same thing as a Zero Gravity DoubleBubble..
I found it makes a world of difference at higher speeds, pushes the air up over my chest more..
I had to put my stock screen back on for a week after my V2 cracked (was not the speedscreens fault) and I noticed the increased wind right away.
-=Welcome To Canada=-
2002 Green 6R
1986 Gixxer 7/11
2002 Green 6R
1986 Gixxer 7/11
I've got the same one, no probs with it to report. Like you said, MUCH better air flow. The only (small) thing I'd like to see would be if the upper edge was had a smoother contour to it.
1 - 9 of 9 Posts
