Does anyone out there know if someone makes a kit for this bike?...i want to relocate my blinkers into my tail light..only problem is that they are LED. any thoughts, links? not really sure if i want to use flush mounts. the lines look so much cleaner without blinkers anywhere..ya dig?
"I'm from yeranus."
You can't split the rear taillight if that's what you're thinking, at least without some pretty significant wiring expertise. The whole led is linked as one signal, unlike the old bike which used two separate BULBS. You can buy wiring harnesses that adapt LP short stalk / flush mount wiring to the stock Kawasaki adaptor if that is what you're after, but the short answer is no, you can't split the rear LED to integrate signals.
Yamaha used to make one for prior R6s, but the catch was, that you had to send your tail section to them to have them do it for you. So, on top of what you spent to buy the product, you had to spend more to have them do it. Don't know if Kawi is coming out with a kit or not, but I figure there will be something out this year. Almost all bikes are going to LED now, so it can't be long. I am thinking about going with one of those kits that make your whole tail light blink really fast to get peoples attention, and then just using hand signals. Not a whole lot of traffic here, so it isn't too bad, just go fast, and you don't have to worry about getting it up the ass from a cage! Good luck. If anyone finds anything, be sure to post the site.
