Looking for reservoir cover door on right side of the tank surround cowl. And if you have it the left glove box door, lock not needed. Might just seal it off if I can't find one, they are useless anyway.
Don't steal one, just make one out of Aluminum. Get a thin sheet from the hareware store about 1 inch (convert to metric) over the size of the rectangle you need to cover area. Make a template from paper from the hole. Make a tab in the template for the tab slot. Also make the template larger than the retangle by a 8 mm. Then cut it out on the aluminum. Mark and cut a hole for the screw. Scribe a line around the retangle about 4mm from the edge. Now use a small hammer to lightly tap and round the edges over. Polish with aluminum cream , find a screw and install.
