Well I bolted it up tonight it sounds great. I do have a couple questions though.
1. The yoshimura instructions mention a kawasaki exhaust gasket. I did not have one on my stock can. The mounting plate on the yoshi is the same shape and material as the stocker so I mounted with out it for now. Do I need to get one?
2. Yoshimura supplies a metal gromet to mount the bracket under the rear pedal. The metal gromet does not fit inside the stock plastic/rubber ones so I went to take both ends of the stock gromets out like the picture shows. But the washer you move to the backside is too small for the hole. So I ended up leaving the backside stock gromet in. Is this correct? Should the metal one supplied fit inside the stock plastic and rubber ones.
Any info would be great. Thanks
