I have read a number of listings about suspension upgrades for the Z750, but some critical info always seems to be missing, can anyone clarify all the following points. This would be really helpful as the only let down of the Z750 is its budget suspension:
Rear Shock:
Which shock should you use (ie: 03 zx636r)?
Does the above fit with no mods?
Does it affect the geometry of the bike?
If yes to above,is it in a good or bad way?
Front Forks:
Which Forks should be used (ie: 03 ZX636R)?
Do you need the whole front end of the donor bike (yokes, calipers etc)?
If no to above, what else do you need to change?
does it affect the geometry of the bike?
any help with the above would be really appretiated as attacking the task at the moment is a very daunting task, only knowing half the info
Thanks
duncan
Rear Shock:
Front Forks:
Thanks
duncan
