Z750S runs, now I have to make the brakes and suspension work better. Suggestions?
232 Views 3 Replies 2 Participants Last post by  Skidmarkart
Howdy all,
So, I got a swell (aka dirt cheap) deal on a non-running z750s... and now it runs. I am rather impressed with the engine on this bike. It's a screamer for a budget commuter! I have been a throttle-wheelie-happy loon this week, and spent several thousand miles of back tire rubber getting a feel for the bike (this tire isn't going to last long, I am afraid).
As I am working through the bike, replacing fluids and whatnot, I have noticed a few items I'd like to improve. First the suspension, it's rather, uh, humble. I am a big fellow, and weigh-in at a mere 235lbs (soaking wet!). I am obviously not who Mr. Kawasaki had in mind when designed the bike. So, if there's any advice about budget upgrades you can lend, it would be greatly appreciated. I have ordered a ZX14R rear shock, which offers much more adjustability, and designed to carry about 50-60lbs additional weight, will likely suit my heft better. Should be a bolt on jobbie from my research. My next mission will be the front brakes and forks.
I'm not trying to do a fork conversion or new calipers, this is my budget project, so nothing radical. Thinking maybe steel lines and EBC HH pads? Anything else? And then the forks, these may be a deal-breaker for me, as they are pretty awful (lots of dive under heavy brake load and unstable as hell over choppy pavement), bordering on dangerously awful. I need to do the seals soon, so maybe drop in some heavier weight springs and thicker fork oil? Maybe a sweet, sweet Chinese fork brace? Am I missing anything? Advice from anyone who knows these bikes better would be appreciated!
I know, it's not a sport bike, and if I am already pushing the limits, maybe it isn't the right bike to keep. But if I can make some marginal improvements on the cheap, it might work well as my commuter.
As always, any advice from you more learn'ed folks is greatly appreciated.
See less See more
Welcome, definitely throw a pair of eponymous aftermarket springs and also check out the SBS pads I recommended in this thread:
I saw more improvement in braking with the new fork springs than with the braided brake lines but it's a good combo nevertheless as every little helps!
  • Like
Reactions: 2
Good thread. Thanks!
  • Like
Reactions: 1
ZX14R rear shock purchased, going to install soon. Checking out the overall weight and bias, this shock should provide about 50-60lbs more carrying weight (which will be helpful for my heavy arse at 230lbs, [yeah I lost 5lbs]), also more adjustments. Also, sweet Chinese fork brace, and considering Race Tech springs more suited to my weight when I do my fork seals (which need to be done soon). Not sure if I will add the gold valve emulators. I have done them before, and they make a huge difference, but they ain't cheap. I will report back on the ZX14R rear shock after install and test riding.
  • Like
Reactions: 1
