Hi i just picked up a 06 zx14 with 5300 miles so it has a Muzzy 4into 1 full system the guy i got it off of handed me a dynojet powercomander 3 i have no idea where this gets installed at on the bike (anyone know),he removed it due to it running to rich. Can anyone tell me if its worth re installing and will i be able to fine tune it on a dyno. Also i see some oil looks like the corner of the valve cover gasket may be seeping not sure. The bike has been sitting a long time and i need to clean it up an go through it an service the fluids. Thanks JIM
Pull the seat, float the tank out of the way. It connects inline at the connector below the rear of the tank on the left side. Install it then get a professional tune. My VC gasket leaks slightly on the front corner, kick stand side. Very common.
Discussion Starter #4
thanks for the info an yes it appears to be leaking on the front kickstand side,I will install the pwr commander an see what kind of #S i pull.
