Hello guys,
A have a huge problem with my zx7r p2 model,
When I go slow no problem running fine,1gear full acceleration no problem sekond gear nearly no proble,
but if I put in to 3 gear it starts jumpimg like crazy,and slovli goest down on sped if i go lover when 100Km/h or 5~6 rpm no problem but if go on acceleration it start jumping and just wont go any ferwer then 110kmh/
may some body know what a problem is ? :rolleyes:
Where was the bike made? Japan spec have speed restrictors which do what you are saying.
Found a problem it was flow in carburators was too low! 1-2 carbs 1.5cm botom of line,
3-4 karbs, 1cm bottom of line, in standart it alowed 0.5mm,so if some body will have same problem here you go an answer!
