hi, does anybody know how i could troubleshoot this problem, first i thought the problem were the bulbs but i replaced and still the high beams didnt work. next i checked the fuses they seemed to be fine also.
how can i test the sockets or relay to see if it is working, the obvious is to use voltmeter, but what should i set it at and what pins should i test it on?
also can someone please tell me where i can find the headlight relay.
bike: 01 zx6r
thanks
raint
take the switch housing part off and check to see if any of the sodered wires have come lose from the actual switch. i had both my low and high come undone from the switch.
just behind the guages.....switch the relays (they are the same) from high and low beams....this will check to see if it is indeed the relay at fault.
square like boxes with snap connection to the harness.
good luck
