So I had an issue while driving where I couldn't change up and down gear occasionally. The problem got significantly worse over the course of a week or so driving.
I've replaced the clutch plates (Steel and friction). I have good tension on the clutch and I can see the plates moving when I do. Although after doing that I seem to not be able to engage the clutch as the back wheel is still locked in gear when I retract the handle.
I'm now wondering if I have a problem with the gear selector/transmission.
Any help would be appreciated thanks.
