If you're talking about putting a standard ZX-7R muffler on a standard '02 ZX-6R header, then yes, I think it would work, although the mounting point at the passenger footpeg might not line up.
That might work. If you can move the mounting point on the D&D can, then I think it would fit, assuming the can is a bolt-on one (to fit Kawasaki headers).
Making a bracket to mount the pipe to the hanger (passeenger footpeg) would be easy, you just would need to make sure that the mounting bolts from the can to the midpipe are the same. Specificlly have 3 bolts.
Note that stock 6R cans have the bolts built into them, whereas I`ve seen some aftermarket pipes (specifically a D&D) that the bolts were seperate and screwed into the can.
Either way, post up if it does or doesnt work, it`d be good stuff to know for the rest of us.
No, but I've seen a full '98-'02 system fitted to a '96 ZX-6R, so I imagine the above info' would apply in this case as well.
