1 - 20 of 36 Posts
The bikes starter clutch went bad when i bought it but the bike was able to push start so i got the bike home and droped the motor and got the starter clutch fixed now i lost spark and i have 12 v at the grey wire of the igniter what do i do did i blow the cdi from to many jump starts?
So to clarify:-
Ignition on and your getting 12v on the end of the Grey wire that goes into the CDI ?
Is the Ignition Switch the Original Kawasaki one or an aftermarket replacement ?
You should be getting a reduced voltage on the Grey wire from the Ignition switch Grey wire to the CDI
Its the original as far as i know and it had a reduced voltage at 6v and now its at 12 volt
Is your Meter Auto Ranging ?
If yes then set it to the Ω setting and probe either side of the Resistor, Allow the Meter to settle as the reading is not instant, It doesn't matter which probe goes on which side there not polarity specific.
Your looking for 100 Ω or there about's as Meters vary in accuracy.
If your Meter is not Auto Ranging then set it to the next highest setting on the Ω scale above 100 Ω.
Discussion Starter #9
my multimeter reads nothing on the resistance so it meens that its blown?
Discussion Starter #11
Well everything els still works fine cant i get a resistor to drop the voltage down to 6v infront of the cdi
You can install it anywhere you like between the Switch and the ECU as long as it's on the Grey wire circuit.
Time to have every connection apart and check their clean and making good contact.
And also make sure everything was plugged back in like the Pick up coil.
Discussion Starter #18
Th
Thanks ill get back to you
i opened the cover on the pickup and cleaned it now it seemes to be firing but not catching like it tries to start and sounds like one cylinder firing but does not want to run
OK it lives sort of (y)
First Check each Plug is prodocing a Spark.
Discussion Starter #20
I got the bike running now even when i jump start the bike the starter just slowly turns the bike and drains the whole system also i think when i reinstalled the clutch that i forgot to put the last plate in the seperate grooves now the clutch is acting up
1 - 20 of 36 Posts
