Hi
I have a problem with my ZZR600
It hadn't been used for 10 years when I got it, cleaned out tank and carbs etc, it now starts not problem
Bike revs fine right through the range when stationary
When ridden there is a flat spot from about 4500 revs, drop a gear and get it above 6500 revs and away it goes no problems
When turning into a head wind or coming out from a slip stream revs die back into the flat spot
It appear to be when air rushes into the air ram intakes to me
Jets are all clean diaphrams are fine, carbs have been balanced
As I understand the ram air system as air pressure in air box increases the float bowls should become presurised and I suspect something is not right here
Any suggestions are welcome
Kevin
Kevin
