Ninja 650 not starting issue please help - KawiForums - Kawasaki Motorcycle Forums
 1Likes
post #1 of 15 (permalink) Old 06-25-2019, 08:10 AM Thread Starter
Chris!'s Avatar
I have a 09 ninja 650 that is not starting unless I pour gas in the throttle bodies or if I use starter fluid little bit of history about the bike it sat outside for at least three months in the florida elements with out a cover on it so far I have replaced the starter solonoid fuel pump spark plugs and tip over sensor still no luck cranks over fine but just doesn't catch I have spark fuel pump sounds like its coming on I checked all the fuses just waiting on the relay box to get here Friday and after that I have no idea where to go from there oh and it has no codes when I tried to use the self diagnose mode all ground wires have been cleaned and I cleaned the injectors still nothing please help will post video tomorrow
Chris! is offline
post #2 of 15 (permalink) Old 06-25-2019, 11:13 AM
bigbadbass's Avatar
Long term disuse and uncovered outdoor storage.....a quick death knell for any motorcycle. Verbal abuse is due the offender who allowed this transgression.
You post you replaced the fuel pump but....is it actually *pumping*? Have you verified? Is there a factory fuel filter? Replaced?
You've drained ALL the fouled fuel that was in the tank and throughout the entire fuel system? ...and replaced with 100% fresh fuel?
Those would be the obvious beginning service checks.
'95 Ducati 900SS/SP
'07 Ducati SS800
'98 Honda VFR800 FI
bigbadbass is offline
post #3 of 15 (permalink) Old 07-13-2019, 02:23 PM Thread Starter
Chris!'s Avatar
Yes even cleaned the fuel rail and the injectors here is a pic of the stator it looked good no burnt coils and here is a video link of the fuel injectors sparying
https://youtu.be/2nIosS4G558
Chris! is offline
post #4 of 15 (permalink) Old 07-13-2019, 02:38 PM Thread Starter
Chris!'s Avatar
Oh and thts with the gas tank plugged in I knoe you can't see it in the video but the pump is plugged in and the fuel line too
Chris! is offline
post #5 of 15 (permalink) Old Yesterday, 08:48 AM
bigbadbass's Avatar
stator? What prompts you to look at the stator in midst of an obvious fuel system issue?
I'd urge you to get into your service manual section on fuel pump diagnosis...your answer will be found there. Very possibly a fault within the fuel pump relay...kind of the "brain" for the pump.
PS "looks good" generally doesn't cut the mustard in regards to electrical items integrity...specific tests exist using multimeters and such. Again, the service manual is your friend.
You DO have a service manual, right?
bpe likes this.
'95 Ducati 900SS/SP
'07 Ducati SS800
'98 Honda VFR800 FI
post #6 of 15 (permalink) Old Yesterday, 10:24 AM
bpe
bpe's Avatar
Service manual
The most essential tool for the DIY'er.
2006 EX500r
bpe is offline
post #7 of 15 (permalink) Old Yesterday, 12:53 PM Thread Starter
Chris!'s Avatar
Yes I've downloaded the service manuel for the bike thanks for all the help and quick response I checked the stator because I've heard that when fuel injectors are not spraying enough fuel it could be cause by a weak stator
Chris! is offline
post #8 of 15 (permalink) Old Yesterday, 08:32 PM Thread Starter
Chris!'s Avatar
Ok so I switched out the new fuel filter with the orginal one (used the new filter tho just switched out the pumps) still no luck I hear it turning on and the fi's are spraying what should I do now
Chris! is offline
post #9 of 15 (permalink) Old Yesterday, 08:34 PM Thread Starter
Chris!'s Avatar
Also when it comes to the fuel pump relay I have replaced the relay box so im not sure what it could be
Chris! is offline
post #10 of 15 (permalink) Old Yesterday, 09:07 PM Thread Starter
Chris!'s Avatar
Oh i also only have about half a gallon of gas in there how much gas do i need in the tank to make the bike start and run?
Chris! is offline
