Ticking noise - KawiForums - Kawasaki Motorcycle Forums
 2Likes
post #1 of 11 (permalink) Old 08-03-2019, 06:28 PM Thread Starter
Hi, I just bought a 2008 ninja 250r and it has 56000kms on it and about a half month ago I started to have a ticking noise coming from the middle of my engine and it only comes when my bike is idling at 1-3k rpms. I'm not sure if it's a cam chain problem or a valve clearance problem from what I've read. The sound also comes when I put the choke off and the bike is warm.
Patrick Miller is offline
post #2 of 11 (permalink) Old 08-03-2019, 08:05 PM
so even if you leave choke on once the bike is warm the noise doesn't come up till after? Last valve adjustment was done at the recommended interval? Sure its not louder on the right side where the cam chain is?
GR rider likes this.
Srb282 is offline
post #3 of 11 (permalink) Old 08-03-2019, 08:06 PM
Video might help if its audible on camera.
Srb282 is offline
post #4 of 11 (permalink) Old 08-05-2019, 05:33 AM
GR rider's Avatar
Your bike needs valve adjustment quite often so check that or have the valves properly adjusted if you are not sure.
It could be normal Kawi noise of course, but check those valves first!
GR rider is offline
post #5 of 11 (permalink) Old 08-05-2019, 10:19 AM Thread Starter
The sound comes when the bike is warm and when the choke is off, it doesn't make the ticking noise after I fire it back up and until I rev the engine or start riding. I'll post a video as soon as I can.
post #6 of 11 (permalink) Old 08-07-2019, 01:55 AM
Are you sure its nothing loose like a clamp that holds choke cable is loose, seems weird that the choke eliminates the noise.
Srb282 is offline
post #7 of 11 (permalink) Old 08-07-2019, 08:19 AM
Very likely the cam chain. Common on the 636's. There's lots of youtube videos on it. My son's was awful. At all times all conditions. The automatic adjuster sometimes doesnt work perfectly. You can get a screwdriver in it to push it one extra tooth. It;s been a while since we did it but there's also a video on how to do the simple fix. As easy as it is to fix I'd at least try it first. Contrary to popular belief Kawi valves rarely need adjustment. My son's bike has about the same miles as yours. Here's a video of the sound before & after
logmaster is offline
post #8 of 11 (permalink) Old 08-08-2019, 09:18 PM
bpe
bpe's Avatar
That may depend on the modal.
2006 EX500r
bpe is offline
post #9 of 11 (permalink) Old 08-09-2019, 10:58 AM
GR rider's Avatar
Absolutely, if I am not mistaken older Ninja 250Rs need valve clearance inspection every 10.000kms or 6.000 miles and the newer models every 7.500 miles.
GR rider is offline
post #10 of 11 (permalink) Old 09-04-2019, 07:28 AM
agreed
I had the 4cyl inlines in mind, of which his is one.
You may post new threads
