can "no wrench noob" install genmar risers on 2006 z750s? - KawiForums - Kawasaki Motorcycle Forums
post #1 of 3 (permalink) Old 08-14-2012, 09:43 PM Thread Starter
i am not much of a wrench.
that said, how difficult is it to install a set of genmar handlebar risers?
will cables need to be extended?
is clearance left turn to right turn an issue?
will the fairing be an issue?
any online "how to" that someone can share?
i was hoping that i would not have to move anything on my present handlebars other than unbolting the bars and setting up the genmars and then bolting everything back.
wishful thinking?
thanks in advance to anyone who cares to share.
be well.
rob
robfilms is offline
post #2 of 3 (permalink) Old 08-14-2012, 10:25 PM
That Fighter Guy
LarryJ's Avatar
Location: Chesapeake, VA '06 ZZR fighter, '11 Harley FLHX
I'd say it's pretty simple. I doubt the risers will bring the bars high enough to warrent longer lines and everything, there's typically quite a bit of slack. You may have issues with the bars touching the front fairing at full turn. Again this is something I wouldn't worry too much about. You rarely need to go full turn anyways.
LarryJ is offline
post #3 of 3 (permalink) Old 08-15-2012, 11:34 AM Thread Starter
larryj-
thanks for your thoughts.
be well.
rob
robfilms is offline
