Z1000 problem (idle speed) - KawiForums - Kawasaki Motorcycle Forums
post #1 of 3 (permalink) Old 03-18-2019, 04:16 AM Thread Starter
Unhappy Z1000 problem (idle speed)
Hi All
I have a little problem with my Z1000 (2016). A couple days ago i cleaned my throttle body.
I started engine and ...
Problem is only when bike have 0-40 degrees temperature. I checked all sensor, main throttle, subthrottle etc (input, output voltage, resistance), everything is ok.
I check all connection (all good), computer don't show any errors.
When temperature have 40-100 degree and i will start engine, idle speed grow to 3000, and very slowly falls down.
When i disconnect main throttle, idle speed is normal.
How can i adaptation main throttle ? Is any procedure ?
Do you have some ideas, what its wrong?
outlive is offline
post #2 of 3 (permalink) Old 03-20-2019, 09:10 PM
Andrew_ironhead's Avatar
Originally Posted by outlive View Post
Hi All
Honestly the video sounds like a vacuum leak. But reading the post further and reading the issue with the throttle makes me think that by disconnecting the throttle it is somehow compensating for the lack of negative pressure in the TBs. I recently did mine on my z750s and found one of my boot seals that goes to the TB wasn't seated properly causing a leak. Just a thought. Or throttle position sensor?
Sent from my SM-N960U using Tapatalk
Andrew_ironhead is offline
post #3 of 3 (permalink) Old 03-26-2019, 03:10 AM Thread Starter
Thanks for you answer.
Yesterday solved my problem. I buyed new throttle and everything it's works fine
But... when i installed again old throttle, engine works fine too, hmm
My theory... computer remembered some bad paramert on old throttle.
When i installed new throttle, conditions changed and computer adaptive to new conditions.
This is my theory, mayby good or bad I have no other explanation.
It is important that everything returned to normal.
Now i have two good throttle
outlive is offline
Similar Threads
I'm running out of ideas! 1994 EX250 Won't idle right, hard to start, idle hangs up. StickSh1ft Ninja 250R 3 11-16-2012 08:08 AM
Idle/Idle Control Knob problem! jjcarter ZX-6R All Model Years 1 06-08-2011 08:59 PM
650r rough idle/no idle smitty24 Ninja 650R, ER6 10 02-15-2010 07:11 AM
Speed display - speed sensor problem? matei 2003-2004 ZX-6R 9 06-19-2008 01:52 PM
'05 636 fast idle / startup idle setting hippo 2003-2004 ZX-6R 14 07-06-2005 03:53 PM
