2001 ZX-6R problems - Page 2 - KawiForums - Kawasaki Motorcycle Forums
 1Likes
post #11 of 18 (permalink) Old 05-05-2017, 11:35 PM Thread Starter
Just checked the fuel relay; the 3rd and 4th lead says it should be 1 ~ 5 and mine read 9. Anyone know if this being high would be causing problems?
ZX6RFromCanada is offline
post #12 of 18 (permalink) Old 05-06-2017, 08:37 AM
zx racer's Avatar
Originally Posted by ZX6RFromCanada View Post
What's the price you're looking for?
50 plus shiping.
Sent from my SCH-I545 using Tapatalk
zx racer is offline
post #13 of 18 (permalink) Old 09-04-2017, 08:31 PM
when my fuel pump died, it got real hot and thats when i knew to replace it.
Rthamilton is offline
post #14 of 18 (permalink) Old 09-05-2017, 12:53 PM
I just realized I didn't actually check the fuel pump solution you suggested... So, when I drained the bowls they did have gas, however, when I took the line off from the carb and turned the key, nothing happened.... Perhaps my fuel pump has just enough power to put fuel into the float bowls, but not enough to actually start the bike?
If it loads the bowls with fuel, its working well enough to start it. It's only when the bike is under load (half or more throttle for a consistent period) that a failing pump will start to be a problem.
CalAussieKTM is offline
post #15 of 18 (permalink) Old 09-05-2017, 12:56 PM
Did it run out of engine oil? Was there oil visible in the sight glass the last few rides?
post #16 of 18 (permalink) Old 02-10-2018, 04:13 PM
I've lost my keys and cant remember for the life of me how to hot wire my bike??? Day. Can some one pls assist me
SlapDick is offline
post #17 of 18 (permalink) Old 05-16-2018, 01:00 AM
AceTS's Avatar
Sounds shady AF...
AceTS - 2002 ZX6-R
AceTS is offline
post #18 of 18 (permalink) Old 06-11-2019, 12:28 AM
check your plugs see that they are tight
life around 160
zx6rmotard is offline
