Oil leak from Stator - KawiForums - Kawasaki Motorcycle Forums
post #1 of 3 (permalink) Old 10-08-2017, 09:34 AM Thread Starter
Daniel Remark II's Avatar
It's not leaking anywhere but out of where the wire runs. I had to replace a broken bolt after replacing the stator and when I ran the motor it was a constant stream of oil. Didn't do this prior to breaking the bolt so I'm not convinced it's the gasket. Any thoughts?
https://imgur.com/a/DoATP
Daniel Remark II is offline
post #2 of 3 (permalink) Old 10-21-2017, 11:19 PM
I've once had to replace my stator cover. Just do so on eBay for a fix that's not too expensive.
MasterFauker is offline
post #3 of 3 (permalink) Old 03-22-2018, 06:58 PM
There's really only two things that could cause that to leak. Either your stator cover is cracked / warped and no longer has a good sealing surface on the left side of your case. Or you didn't remove enough of the old paper gasket off of the sealing surface when you replaced your stator causing it not to create a seal. (seen this 100 times) I am however assuming you did put a new gasket on when you reinstalled the stator cover, those are meant to be a one time use only.
2008 NINJA 250R TOTALED
2014 NINJA 300 SE SOLD
1992 NINJA GPX ZX600C PARTED OUT
1989 NINJA GPX 600R
2008 NINJA ZZR 600
zxkyler is offline
