05/06 ZZX6R Charging Issues - KawiForums - Kawasaki Motorcycle Forums
post #1 of 1 (permalink) Old 04-10-2019, 12:48 PM Thread Starter
Hi I am new to the forum and a new owner of a used ZX6R which I purchased in the fall pretty cheap and was sure I would find a few gremlins hiding within.
Low and behold it has charging issues which from what I have read is not that uncommon, the bike has 26,000 kms and appears to be in good shape and no signs of being dumped.
I have the shop manual and have read several threads on the subject but none have mentioned what I have found when following the rectifier circuit check. When I follow the procedure in the manual I am getting the complete opposite readings of what I should be getting.
Example
- Multi meter set on diode function
- red lead to connectors (BK1,2,3)
- negative lead to BK/BL
= I get a reading of 8 on all three and when I reverse the leads, I get infinity
The same test with the negative lead to BK/W provides the same result.
I have taken every reading and I get the opposite of what the manual says I should have. From reading threads and watching some videos on how to check rectifiers you are looking for consistent readings and that all 3 diodes only allow flow in one direction.
I have read it is not uncommon for after market parts to be faulty or wired incorrectly, so my common sense is telling me the wires are reversed. The colour of the wires is accurate, which means it would be reversed inside the rectifier.
Has anyone come across this issue?
I have checked the stator and only see voltage through two posts, so I know that needs to be replaced. However I am worried that the rectifier could have caused the stator to fail, but may be a simple fix by swapping the wires around on the rectifier.
Again as anyone come across this issue?
Thanks
PS: I have done the tests three times over, the leads are on the right posts
Stinkarse is offline
Similar Threads
ZZR 600 charging issues stevo 64 New Member Introductions 1 06-09-2018 04:44 PM
Charging issues Crb1994 New Member Introductions 2 09-06-2017 12:35 PM
Charging Issues KawZR7 New Member Introductions 3 05-18-2015 11:19 AM
charging issues with my zx6 lezbiian sweetz ZZR600 & ZX-6R Old School 4 10-23-2010 05:49 PM
Charging issues... Possible solution bignastyjb 2005-2006 ZX-6R 0 08-31-2008 02:20 PM
