Installing the ZX9 engine in my ZX7 frame - problem! - KawiForums - Kawasaki Motorcycle Forums
post #1 of 2 (permalink) Old 03-24-2019, 10:17 AM Thread Starter
ZX7-Mike's Avatar
I have fastened the lower rear engine mount, and begun to raise the engines front up against the upper mounts, when...the engine gets in contact with the frame!
Se the attached picture:
ZX7-Mike is offline
post #2 of 2 (permalink) Old 04-02-2019, 01:51 AM Thread Starter
ZX7-Mike's Avatar
No one here have done this 9/7 swap on a P model ZX7R?
This is a guide on another site:
"..If you don' t want to go the BRG route, you can get around the front engine mount problem by wittling out the other engine mounting holes on the engine, this will give enough movement to install all the mounts on the standard frame. Second up is the oil delivery pipe to the cylinder head. This will require a little frame modification in order to clear the banjo bolt. Third up is the airbox, in order to use the 9r carbs try to get hold of a 9r B base for the airbox, the carb mounting face is then cut out and plastic welded (using soldering iron) into the base of the 7r airbox. this allows the use of 7r airbox with filter and ram air tubes."
The main issue though, is to be able to rotate the engine when it is inserted in the frame opening. To get the lower mounts on the engine and frame to match, the engine has to be rotated forward.
How the heck is this to be done when the engine is placed on a jack?!
Tilting it forward or backward is no problem...but rotating?
ZX7-Mike is offline
Similar Threads
zx9 Alternator chain lower tensioner 94-97 zx9 or zx7 dennis72184 Wanting To Buy 0 12-06-2008 06:19 AM
93-95 ZX7 & 94-97 ZX9 engine/body parts FS kawzxr6 For Sale - General 0 11-28-2007 02:24 AM
01 zx9 engine, can I get it in a 94 zx7 frame? Fawn ZX-7R 18 10-01-2007 08:01 PM
zx7 to zx9 back to a zx7 insanebiker05 ZX-7R 4 04-09-2006 11:10 PM
FS: 94 zx9 parting out some 00 zx9 and 02 zx7 parts nuclearr For Sale - General 2 03-28-2006 03:14 AM
