Bike died while pulling clutch lever - KawiForums - Kawasaki Motorcycle Forums
post #1 of 9 (permalink) Old 11-24-2009, 07:17 PM Thread Starter
What up everyone! I was cruising today at about 60 mph and pulled in my clutch lever and the engine rpm dropped all the way down and the engine stalled out. I restarted and tried it again, same result.
When I am coming to a stop and downshift through the gears, this does not happen. The bike is a 2007 ZZR 600, 15k miles, and seems to idle fine otherwise.
Just looking for advice as to where to look for a problem.
-Jacob
jz321 is offline
post #2 of 9 (permalink) Old 11-24-2009, 07:45 PM
03'636's Avatar
Send a message via AIM to 03'636
Try adjusting the idle a little higher and see if that helps.
July '09 BOTM
03'636 is offline
post #3 of 9 (permalink) Old 03-29-2010, 11:15 AM
I have aq similar proble ,bike just stalls when I cruise to a stop but starts right up and idles fine.any idea what might be wrong?
carlnelly is offline
post #4 of 9 (permalink) Old 03-29-2010, 03:09 PM
Tober113's Avatar
so at 60 mph you are not downshifting? just pulling the clutch in and stopping? what gear are you in when you pull the clutch in?
Tober113 is offline
post #5 of 9 (permalink) Old 03-29-2010, 05:59 PM
Maness1220's Avatar
So what happens if you just let the clutch back out?
Have you done any carb work to the bike? Had the air box off?
Might be a vacuum issue.??? or a fuel pump.??
"He who lives by the sword,
Will need to practice with it often."
Maness1220 is offline
post #6 of 9 (permalink) Old 03-29-2010, 06:22 PM Thread Starter
Nah, I downshift through the gears when coming to a stop. I was just seeing if it would hold an idle when the clutch was pulled in dropping from ~6k rpm cruising. I was and still have issues with the engine dying if the throttle isnt feathered as you reach idle when stopping/downshifting. Once idle is reached the bike will hold it on its own.
Quick stop with no downshift and no throttle feathering will just about always result in a stall......
All stock, carbs have never been apart, 2007 with 15k miles.
*edit: Maness, I have had the airbox apart a few times to clean the air filter, the gasket around the box seemed to be ok. Also, the time it stalled when the clutch was pulled cruising at 60, i let the clutch back out slowly and it fired right back up as expected.
-Jacob
jz321 is offline
post #7 of 9 (permalink) Old 03-29-2010, 08:29 PM
Maness1220's Avatar
Now you hit on something there, See mine does not do like yours,
But if I make a sudden stop, Like pull in the clutch & hall on the brakes without down shifting
it will sometimes stall. Then fire right back up.
I'm no tech, but I think this is just an inherent problem with carbureted bikes.?????
You on the other hand seem to have a larger problem.
post #8 of 9 (permalink) Old 03-30-2010, 11:03 AM
Mark-J's Avatar
Send a message via MSN to Mark-J
Maybe when braking very hard, the fuel will go forward and won't reach your carbs of something? I once heard about an oil light going on when braking very hard, because the oil would be pushed to the front in the reservoir
I think your idle RPM is too low. Does it also stall when you're standing still after driving for a little while (without the hard braking)?
Kawasaki ZX6R 1998!
Mark-J is offline
post #9 of 9 (permalink) Old 04-02-2010, 09:56 AM
Bike stalls
I changed my carburator and it seems to help but stalled like twice on me. I will change my fuel pump to see if that problem goes away then post back. keeping my fingers crossed.
