Badassjakes super streetbike build final round - Page 6 - KawiForums - Kawasaki Motorcycle Forums
 12Likes
post #51 of 57 (permalink) Old 12-06-2017, 09:09 PM Thread Starter
badassjake's Avatar
And again.....we go
Head is decked, -0.024".....stroker crank is installed.
All new rings ordered and installed.
Middle shifter fork ordered. Transmission is in great shape.
Had small signs of detonation..... And also very light piston to valve contact. Ordered a couple intake valves just cause.
badassjake is offline
post #52 of 57 (permalink) Old 01-01-2018, 09:02 AM Thread Starter
badassjake's Avatar
Motor is back together..........one must shim the spark plugs when doing an aggressive shaved, as the electrodes will get knocked closed from tapping the piston.
A quick cam timing check, and all seems in order for the initial break in. I'll go back and check the compression once the rings get seated and oil is throughout the motor.....usually after the first tank of gas is enough for me to recheck and tidy up loose ends.
Did some fairing wrap of carbon fiber....i'm content with it for now, will have to see what it looks like on the bike to see if its' gonna stay.
post #53 of 57 (permalink) Old 01-20-2018, 07:22 AM
Phenomenal's Avatar
I running these on my
They are a bit shorter, talking about something like -2mm vs ngk cr9e.
Phenomenal is offline
post #54 of 57 (permalink) Old 01-20-2018, 08:53 AM Thread Starter
badassjake's Avatar
yeah, I didn't have much luck with Brisk plugs, had two plugs go bad on two separate motor's/builds.
I just stick with good old NGK.......but also choose surface gap plugs too.
https://www.ebay.ca/itm/NGK-Spark-Pl...oAAOSw575ZhBtY
post #55 of 57 (permalink) Old 02-23-2018, 10:24 PM Thread Starter
badassjake's Avatar
New covering for the fairings turned out ok. Couple heat cycles done.....once the roads get clean, it will be test ride and tuning.
Been trying to upload pics, but for some reason it keeps kicking me out with an errror...laptop or phone.
post #56 of 57 (permalink) Old 05-22-2019, 05:39 PM Thread Starter
badassjake's Avatar
Well, it's done. Went back to classic look with a fresh coat of paint.
ID:	131581   Click image for larger version
ID:	131583   Click image for larger version
GR rider likes this.
post #57 of 57 (permalink) Old 05-23-2019, 03:32 AM
GR rider's Avatar
Good job
GR rider is offline
