Badassjakes super streetbike build final round - KawiForums - Kawasaki Motorcycle Forums
 12Likes
post #1 of 57 (permalink) Old 11-05-2014, 04:52 PM Thread Starter
badassjake's Avatar
Master list of bike mods:
Built 2005 Zx6R motor(bored,ported/polished,lightened/balanced crank,degreed cams, etc, etc,etc)
08 Zx10 radiator
NRC engine covers,left and right sides
HyperPro aluminum clutch pack/HD springs
05 ZX6R front end
08 ZX10R swingarm and 06 Zx6R shock/linkage
ProLite rear rotor and Ti bolts
Magnesium Marichensi Rims
Brembo Rotors w/Dunlopad HH pads
EK-3D 525 chain
Race Zx10 tail section with custom LED lights
Fiberglass front fender
03 Zx6R gas tank with Fuel Foam
Full Muzzy system
ALOT of various Titanium and Carbon Fiber bits and pieces.
Daytona Steering damper
Vortex rear sets
Carbon Fiber clip on bars
Woolich Auto Tuning programmer
Ballistic battery
Servo Buddy eliminator, and Secondary Servo Buddy eliminator
Innovate wide band setup
All non-essential stuff removed, but still street leagal-ish.
I do believe that the end all and final list of upgrades has come about.
List of changes to undergo this round:
1. swap out old rims for the Marchesini beauties---CHECK
2. remove supercharger ---CHECK
3. install 08 Zx10 rear swingarm---CHECK
4. remove the ram air assemblies and unwanted ducting.---CHECK
5. 08 ZX10 radiator---CHECK
6. install NRC covers left and right sides.---CHECK
7. install aluminum clutch plate kit---CHECK
8. PC3usb with quick shifter---CHECK
9. swap out 80psi fuel pump for 60psi version---CHECK
10. remove red accent striping and ZX6R sticker.---CHECK
ID:	105586   Click image for larger version
Name:	old and new.jpg
badassjake is offline
post #2 of 57 (permalink) Old 11-05-2014, 09:04 PM
basco's Avatar
Epic build shall be epic
2005 ZZR600: Daily- Custom Muzzy's/Brocks/Yoshi full exhaust, Ivans Jet Kit, Muzzy's Advancer (~+5*), RaceTech internals front and rear
2001 Buell Cyclone: track whore
basco is offline
post #3 of 57 (permalink) Old 11-12-2014, 05:52 PM
That Fighter Guy
LarryJ's Avatar
Location: Chesapeake, VA '06 ZZR fighter, '11 Harley FLHX
You sir are just never happy. Are you? Ha ha.
LarryJ is offline
post #4 of 57 (permalink) Old 11-12-2014, 06:26 PM Thread Starter
badassjake's Avatar
Always happy, I just keep finding more happiness
post #5 of 57 (permalink) Old 11-14-2014, 07:19 PM
That Fighter Guy
LarryJ's Avatar
Then you're a happy busybody. I wish I had time to mess with my bikes. Hell I have a Z1000 motor and frame I need to get together for my next fighter project. The motor has been sitting on my bench for a year and a half. I gotta hone the cylinders, get new gaskets, new valves, etc. Stupid previous owner left it outside with no plugs in it for several months. Had 3400 miles on it before the original owner dumped the bike and sold it. Rust all over the valves and the engine full of water and old oil. Ugh.
Good luck on this new build. Keep up the great work.
LarryJ is offline
post #6 of 57 (permalink) Old 11-25-2014, 09:06 PM Thread Starter
badassjake's Avatar
The 05/06 rad was bigger then the 98-02......... add one 2008 ZX10R rad and I dare say it's like a superbike kit rad that one could only have dreamed of back in 2000 and not pay a fortune for.
Thank you Ebay and squids.
post #7 of 57 (permalink) Old 11-26-2014, 11:18 PM Thread Starter
badassjake's Avatar
one rolling chassis later...............
post #8 of 57 (permalink) Old 12-02-2014, 03:37 PM Thread Starter
badassjake's Avatar
The spacer for the boost decompression was too thick, and I had to cut down the spacer. I was waiting on end mill parts from Ebay to arrive.
It was a tricky little job, but i managed to make it work.
Now it's a matter or assembling the motor, degreeing the cams and stuffing it back into place.
post #9 of 57 (permalink) Old 12-04-2014, 05:22 PM Thread Starter
badassjake's Avatar
motor back together....re-degreed....swapped out the drag clutchpack for the Aluminum clutch pack setup I also run.WHOLE bunch of weight lost there.
NRC covers installed......time to go back in frame!
ID:	106338   Click image for larger version
post #10 of 57 (permalink) Old 12-05-2014, 05:13 PM Thread Starter
badassjake's Avatar
progress today......winter is holding back for the day, sunshine is wonderful.
rad mounted up quite nicely. small mod to the inner fairing for clearance, but a success!!
Pod filters accepted the secondary injecters perfectly.
ID:	106361   Click image for larger version
