Hot start issues - KawiForums - Kawasaki Motorcycle Forums
 1Likes
  • 1 Post By badassjake
post #1 of 5 (permalink) Old 05-21-2018, 06:00 PM Thread Starter
Hot start issues
2007 ZZR 600
Been having some hot start issues since the end of last season. Facts:
- Starts easily when cold (with a little bit of choke and usually a touch of throttle for good measure)
- If I Start it back up within a minute after shutting off it will start, but only with a touch of choke.
- Let it sit for a while (say 3-5 minutes) and it will fail to start with any combination of choke/throttle
- Letting it cool down for 15-30 minutes and it will *usually* start again, with choke and throttle.
- Will always start again after waiting extended periods of time (many hours/days)
- Was unable to bump start or jump start
- I believe the bike runs rich (plugs looked quite fouled last time i pulled them, 1.5 years ago)
What could I be looking at here, and what kind of troubleshooting could I perform to narrow down the issue?
Any help much appreciated.
Matty8 is offline
post #2 of 5 (permalink) Old 05-21-2018, 06:07 PM Thread Starter
Based on some of my research, running rich could be the problem. Noob question, but how do I lean it out? I've worked on the carbs before but I'm not sure what is required to change the ratios, and my service manual did not specify.
Matty8 is offline
post #3 of 5 (permalink) Old 05-21-2018, 07:15 PM
WildCard's Avatar
I would clean the carbs really well and replace the plugs before messing with the jetting. Hot start issues might also be a problem with the valves, do you know when they were adjusted last ?
damned. " - WillBrink
WildCard is offline
post #4 of 5 (permalink) Old 05-21-2018, 08:59 PM Thread Starter
Carb clean was done end of 2016.
Plugs only ever cleaned and gapped, never changed that i know of.
valves never adjusted in 18k miles.
Matty8 is offline
post #5 of 5 (permalink) Old 05-22-2018, 10:45 AM
badassjake's Avatar
typically tight valves make this condition.....if it was too rich, then it would typically start cold without choke.
WildCard likes this.
badassjake is offline
