1999 zx6 gear issue - KawiForums - Kawasaki Motorcycle Forums
post #1 of 8 (permalink) Old 02-28-2019, 02:39 PM Thread Starter
VintageApples's Avatar
1999 zx6 gear issue
So this has only happened twice but that’s two times to many. When I pull away and try to accelerate quickly going through 1st and 2nd is fine but when I click into 3rd it’s like it is in neautral. It over revs and doesn’t engage until I put the clutch in and back out then it ingages. This doesn’t happen every time but it’s happen trying to pass a car and that was rather uncomfortable being powerless. Fairing new to doing my own mechanics on the bike so I’m not really sure where to start. That chain isn’t that tight and it’s just had a fresh oil change. Any info would be much appreciated thanks
VintageApples is offline
post #2 of 8 (permalink) Old 02-28-2019, 08:56 PM
badassjake's Avatar
Sounds like the engaging dogs for the gears are rounding off. Simple surgery, but extensively deep in the motor.
badassjake is offline
post #3 of 8 (permalink) Old 03-01-2019, 03:17 PM Thread Starter
Okay I will look into that and see if I have the tools and things necessary to check it. Thank you very much.
Also is there a page or a video that has good coverage on getting to them?
post #4 of 8 (permalink) Old 03-01-2019, 03:47 PM
bpe
bpe's Avatar
A service manual can come in handy.
2006 EX500r
bpe is offline
post #5 of 8 (permalink) Old 03-01-2019, 04:39 PM
bigbadbass's Avatar
Good advise @bpe. Its actually ESSENTIAL that OP read the applicable sections in the service manual, digest what is entailed and needed PRIOR to jumping in.
Doing so with no reference material and prior research whatsoever is a recipe for disaster.
I must disagree with "simple" comment posted above.....engine removal and crankcase splitting hardly simple.
'95 Ducati 900SS/SP
'07 Ducati SS800
'98 Honda VFR800 FI
bigbadbass is offline
post #6 of 8 (permalink) Old 03-06-2019, 02:16 PM Thread Starter
I had thought as much. Of coarse the bike did not come with a service manual but I can get my hands on one. Will be doing a lot more looking into before I jump into taking my bike apart.
post #7 of 8 (permalink) Old 03-07-2019, 06:17 AM
Take it from me just replace the gears my bike did what you're describing after I bought it (in 4th/5th though) gunned it one day and the gearbox siezed locking the back wheel at 130mph .
It was a simple job for me without a manual with one or 2 sticking points other than that a screwdriver and socket set will do more or less everything, as I say thouugh I found it simple you may not and thats fine but dont force it everything you're gonna be working with should be really easy to get in/out with minimal force if you REALLY get stuck ask someone for help cus it can go from simple for me to nightmare for a mechanic real quick and its not worth riding on a botch job.
The real pain for me was the clutch basket retaining nut, it tightens from being under load so when you get to it if you dont have a clutch basket tool you're gonna have a really hard time getting it out we tried everything and ended up cutting it off in the end but with the clutch tool a decent breaker bar and a 25mm? (i think) socket will do.
Other than that once you've got the clutch basket out go ahead and take the engine out (I found it easier to semi strip it down while it was on the bike) turn it over and there are some big bolts on the bottom once you've taken them out and split the case (shouldn't really take much tension dont be like me and wedge it with a screwdriver could be you missed a bolt just tap the sides with rubber mallet to get it to realease) the gearbox is right there pay attention to how it is orientated take the 2 mounting shafts for the selector forks out and the gearbox should basically fall out.
Go slow and take pictures I would strongly advise that if you go for a complete box make sure to get new shifter forks as they tend to wear out you may as well replace them (mine were so worn they had jagged edges and one of of them had a piece of the fork broken off) while you're there and give the selector drum a good look make sure the tracks dont have rounded or stamped edges otherwise that will ruin your new box.
While its open give everything a once over for wear cant hurt and may show up some other little gremlins waiting to pop up, I'm unsure if its nessisary but its a good idea to make sure that the gearbox is in neutral when you put it back together so it turns freely and everything rests in place.
Also make sure you use silicone sealant around the edges when you put it back together except on the big bearings (you'll know it when you see it) otherwise its gonna be leak city.
You'll likely need help to get the engine back into the bike, after 4 hours failing to get it on my own the way the manual tells you to I layed the bike on an old mattress and went in sideways with my dad guiding it job done.
As I said before as long as you take it slow pay attention and dont force anything (clutchbasket nut again is a pain in the neck but if you put a complete box in you're replacing it anyway long as you dont damage the basket go wild) you should be just fine, but dont half-ass it or cheap out if I were you it would be new gears new forks new drum (or within reasonable condition from a breaker) and remember to break it in slow the gearbox has to wear to the engine a bit first.
hope this helps
nauroticdax is offline
post #8 of 8 (permalink) Old 03-30-2019, 04:59 AM Thread Starter
Originally Posted by nauroticdax View Post
Take it from me just replace the gears my bike did what you're describing after I bought it (in 4th/5th though) gunned it one day and the gearbox siezed locking the back wheel at 130mph <img src="https://www.kawiforums.com/images/KawiForums_2015/smilies/tango_face_crying.png" border="0" alt="" title="Crying" class="inlineimg" />.
hope this helps
This does help, will be replacing it once I get the money to do so. Saw a mechanic who reckons it would be fine but he also said my soloniod was dead yet it fired up with it... so, not much trust there.
Similar Threads
Cooling issue And clutch issue Fastkawi05 2005-2006 ZX-6R 1 04-18-2013 10:33 PM
Starting issue Ninja 1999 9R mad_ninja New Member Introductions 2 03-22-2012 11:29 AM
WTB: 05/06 zx6, 07/08 zx6 parts, riding gear. PAYPAL READY!!! 06blakninja Wanting To Buy 4 03-08-2011 01:50 PM
WTB: 03-04 zx6 AND 05-06 zx6 RADIATORS, 05-06 zx6 right rearset Lockmaster Wanting To Buy 1 02-21-2011 11:51 PM
1999 Kawi zx6r 2nd gear Christianl ZZR600 & ZX-6R Old School 0 03-23-2007 10:25 AM
