2005 ZZR600 Front Turn Signal replacement/install help - KawiForums - Kawasaki Motorcycle Forums
 1Likes
  • 1 Post By PythonRules
post #1 of 4 (permalink) Old 04-20-2019, 02:01 PM Thread Starter
Hey everyone. Hoping someone can help. My OEM turn signals broke near the base (rubber failed). I bought K&S OEM type replacements for reinstall. I removed the front fairing and the old turn signals. I'm attempting to install the new signals now. For the life of me I can't get them into the factory holes with or without the metal piece at the bottom of the stock. They are exact matches to the OEM ones so they should work. I'm thinking their must be a technique that makes it easier. Thoughts?
PythonRules is offline
post #2 of 4 (permalink) Old 04-21-2019, 08:19 AM
bpe
bpe's Avatar
The correct way would be to install without the plate, and then put the plate on afterwards. I know you already tried that. Mine squeeze in and out pretty easy, so I'm not really sure why yours are hanging up. Maybe if you used some type of lubricate it would be easier, tire lube comes to mind.
2006 EX500r
bpe is offline
post #3 of 4 (permalink) Old 05-05-2019, 09:27 PM Thread Starter
Just following up on this thread hoping it will help someone in the future. It turns out the bottom of the K&S signals are made of a hard plastic material instead of the more flexible rubber like material of the OEM ones. This makes it impossible to get it into the hole since it isn't flexible enough and lube didn't help. I ended up buying new OEM turn signal bottoms and connected them to the K&S signals. Went in easy.
bpe likes this.
post #4 of 4 (permalink) Old 05-15-2019, 01:32 PM
Monstermack's Avatar
Surprised someone actually wanted to keep the stock turn signals. That was always one of the first things people swapped on those bikes.
"Life is like a Penis:
Simple, soft, relaxed, and hanging freely. Then a woman comes along and makes it hard."
Originally Posted by strat1701 View Post
i was thinking more in terms of explosive diarrhea spray but you seem to have erect penises on your mind...
Monstermack is offline
Similar Threads
front turn signal replacement rikker Ninja 250R 19 09-27-2010 04:10 PM
08 - Turn Signal - Broken Front Left Signal MasterPat Ninja 250R 7 07-17-2008 02:57 PM
Need help with front turn signal install csteuble 2007-2008 ZX-6R 4 05-27-2008 07:33 PM
Front Turn Signal Replacement, help!! billyboot ZZR600 & ZX-6R Old School 3 06-03-2007 09:09 AM
A replacement for Front turn signal lights? lizzzi 2003-2004 ZX-6R 7 02-03-2004 07:12 PM
