Need help! - KawiForums - Kawasaki Motorcycle Forums
 1Likes
  • 1 Post By hilltopzombieshop
post #1 of 8 (permalink) Old 07-23-2019, 05:53 PM Thread Starter
Need help!
I have a 07 zzr600 motorcycle, my front brakes are out. When I’m not moving they build pressure, but when Im commuting somewhere they disappear. No pressure or anything. What could it be?
Kingjackson28 is offline
post #2 of 8 (permalink) Old 07-23-2019, 07:35 PM
bpe
bpe's Avatar
Try changing out the fluid and bleed it.
2006 EX500r
bpe is offline
post #3 of 8 (permalink) Old 07-23-2019, 09:32 PM Thread Starter
I’ve done that multiple times.
post #4 of 8 (permalink) Old 07-25-2019, 08:52 AM
badassjake's Avatar
sounds like a warped rotor
badassjake is offline
post #5 of 8 (permalink) Old 07-25-2019, 01:20 PM Thread Starter
Wouldn’t I still have pressure and wouldn’t the bike shake whenever I’d pull on the break?
post #6 of 8 (permalink) Old 07-25-2019, 01:22 PM
GR rider's Avatar
Probably but not necessarily.
GR rider is offline
post #7 of 8 (permalink) Old 07-27-2019, 03:02 AM
badassjake's Avatar
Jack up front wheel, use a pencil or some sort of pointer, spin the wheel and hold the pointer close to the rotor you should see the gap modulate, if it is a long warp it will be gradual.
post #8 of 8 (permalink) Old 07-31-2019, 01:52 AM
I think you have a blown ring on your master cylinder. It can create the illusion of pressure until you actually use the brakes and then lose pressure when the fluid passes by the piston. I blew one on a Harley Sporster when I had to make an emergency stop on the freeway. You can replace the internals with minimal time and skill. A rebuild kit should be cheap. All the bleeding in the world won't cure a blown master cylinder.
GR rider likes this.
hilltopzombieshop is offline
