First, this set of guide lines is written around conventional forks. Upside down forks will be different and require you to get a "real" seal driver.
The instruction also assume some basic knowledge and tools. A means of supporting the front of the bike is a given...using a rear stand for stability is recommended.
As with any job, get yourself a clean place to work, lay out a towel or some rags to lay parts out on.
Before removing the fork tube from the bike, you want to break the cap loose (blue in the picture), don’t remove it, just break it loose. Also back off the spring preload all the way (silver in the picture) and turn the rebound dampening screw all the way in to the last click (brass screw head), do not “tighten” it.
