AjR1's 98 ZX6R Track Bike Build
17K views 49 replies 14 participants last post by  AjR1
#1 ·
Well I picked up a 98 ZX6R Track Bike for $1500 with the intention of giving it a freshen up. Only 40k on the clock.
Pic as it stood in the Ad.
Its an older model and a bit tardy looking but mechanially all good from what I could see. Will know more once I get it home and start stripping it down for a once over.
All loaded up and ready to transport home
#5 ·
High as a kite on paint fumes and the frame is all painted. Now just gotta let it all dry.
Well after getting around to removing the braking system.
I found that the rear caliper was seizing up.
So after pulling it all down.
There is a bit of corrosion going on.
Since I will be overhauling the rear I may as well do the fronts aswell, So its time to order some caliper kits and clean these up & paint while im waiting for them to arrive.
Well I finished off the Pair Valve mod. So only fresh air into the motor from now on.
Also changed out the plugs as well today.
Gave the frame & swinger its 6th and final coat.
Plus all the other little bits aswell.
And also rotated the bottom shock mount 180deg so the adjuster is not blocked by the exhaust.
#6 ·
Modified the Exhaust as it had a bit of rash damage on the bottom of the can.
Next step Cermaic coat, then Badge modification.
Bought a few things for the Trackie today
Tinted DB Screen
Clear SS Lines F&R
Black Fuel Cap
Green levers but with orange adjusters
Black Rear Sets
Rear Cowl Decal
Frame Sliders
Header Gaskets
Fork Adjusters
Tank Decal - But in Black
Various Michelin Decals for front fender etc...
Upper Ninja Decals
Black Oil Cap
Rear Caliper Kit
Rim Stickers to replace the current blue ones.
Various Sponsor stickers for the belly pan etc...
#8 ·
Very nice. I like the paint idea.
Sent from my PC36100 using Motorcycle.com Free App
#12 ·
Looking good so far Im diggin the paint idea
Sent from my SAMSUNG-SGH-I997 using Motorcycle.com Free App
Looking good, can't wait to see it finished.
McDonalds coffee ? I thought you folks down under just drank Cooper's and kangaroo piss... :D
Cheers guys. I definately cant wait till im done. Keen to hit the track.
Well you can definately compare Maccas Coffee with Roo Piss. Couldnt really taste any worse. :Laughing rolling:
#11 ·
#13 ·
Quick update:
Starting to go back together. Kinda looks like a bike.
Filling in the holes in the exhaust where the badge was rivited. Will fill it up again once set and then sand it back ready for more paint. Decided not to go with the badge.
Base coat on the race glass all done. Now just have to let it cure for the week before taping it up and doing the top colours.
Since the glass is going to be replaced later on it was just a quick job, The tank on the other hand will not be replaced and I'm taking a bit more care with the prep and finish on this one. All sprayed up with primer filler. Couple more coats to go and then ready for a light sand and paint.
Rear caliper all cleaned up and painted. Excuse the white paint dust. Will wash right off with the first bath once its all back together.
I have got the base coat down on the tank. 7 coats in total and still one more to go. Then its curing time for a week before taping it up for the top coat colour.
Here's a few pics of my pressure pack handy work.
And a couple of close up shots.
#16 ·
Cheers WildCard, appreciate it bud.
Well the tanks almost done.
Close up (Not to shaby for a rattle can)
Rear cowl where my young fella dragged it along the concrete.
All taped up ready for the green.
Did someone say "Sexy Tank" ?
#19 ·
Wow... You weren't kidding when you said you were going to tear it down!
And that tank looks great!
Thanks bud. Yeah didn't want to be riding someone elses problem. So would like to know that everything is going to work as it should when I get to the end of the main straight. :Laughing rolling:
That paint looks pretty damn good. Is that all just from a rattle can ?
Cheers again man. Really happy with how the tank has come out so far.
Yeah just out of the cans I put up in the first post.
I have started spraying up the tail. Had to change the layout of the colours though as the young fella damaged the white in areas. Didnt want to repaint so just covered up the good and resprayed the bad areas.
Green first. Top will be orange with white number boards.
#22 ·
Are those rear sets from Dan-Moto I was not happy with the fit of the rear brake MC on those. Shifter side was nice and solid with a good solid feel brake side I never could get to fit right with stock parts, I had to grab different bolts and grab a different MC and clearance some areas to get it to fit and feel semi solid. Let us know if you have better luck with yours.
#23 · (Edited)
Yeah mate they are Dan Moto rearsets.
Will be fitting them up tomorrow so will see how I go.
Everything looks to be in order though.
Well made a little progress today.
Got the rear cowl finished off and clear coated,
along with the tank and installed the new filler cap.
Upper &Lower's painted up with the green, just have to tape it off again tomorrow and finish off the orange, touch up the white where my young fella scratched it up and clear coat it all.
Front fender all painted up and clear coated
Tomorrow I'll be Installing the levers, rearsets, fork adjusters and work out how I'm going to get the front off the ground to remove the wheel so I can paint up the forks & front wheel. Stick the tank pad on and get the rear end of the bike reasembled atleast.
Should be a busy day at this stage.
#24 ·
Left rearset installed.
Fork Adjusters Installed
Oil Cap Installed
Rear Brake Master Painted Up. Just waiting for it to dry and then I can assemble the Right Rearset
New Levers
Clutch side installed
Brake side on the master.
#25 ·
Well I did a little more tonight and will be back out in the garage shortly once everyone is asleep so I can work undisturbed.
Removed the blue rim tape and installed the new decals
Looks the part now.
Installed the rear wheel again and adjusted the chain (excuse all the dust and mess, My
apprentice was off today)
Brake Caliper Bracket all painted up.
Rear cowl & Seat mocked up before final install.
From another angle with the new decal
#26 ·
Well its time for bed so this is the last update for the week, untill I get back from work on friday.
Pretty happy with the progress so far.
Tank is completely finished. Decals & Tank Pad on.
Upper is all painted up, Just need to let it cure then its time for a rub back and clear coat.
Lower is all finished and belly pan decals applied.
#28 ·
Cheers mate. Starting to come together nicely.
Well I actually did a little more today as work is stressing me out and needed a release of sorts.
Rear cowl all stickered up.
Upper all clear coated and stickered up.
