05-06 ZX6R/RR Change out shifting forks
1 reading
187K views 120 replies 32 participants last post by  wolz
#1 ·
To do this you will NEED A SPANNER CLUTCH TOOL!!! I have tried without one and broke my clutch basket which is $300 the tool is only like $30 so buy one or borrow one. If you have been wanting to install an after market shift start now is the time. I would suggest still having a manual when doing this to reference too. I am not responsible if you pull it apart and mess up or can't put it back together..... sorry. It's really not hard to do but some people can't even change plugs so please know your own limits.
1)Pull your fairings off. For stock fairings just the sides and lower should be good.
2)Unbolt your radiator and tie it forward against your front tire so you can reach the header bolts easily and not damage your radiator.
3)Remove your headers and exhaust. You might not have to completely remove everything but you need to make sure none of it is blocking the oil pan from dropping straight down. I had to remove everything but the can under the tail.
4)Drain the oil thru the plug on the oil pan and then pull the clutch cover off of the motor and remover your clutch.
5)This next part is probebly the hardest part. You WILL NEED the clutch tool to do this. I have broken my clutch basket before and they cost $300. Once you have the tool you will need an impact or breaker bar to remove that bolt. Take your time and DO NOT round it off.
6)To be able to remove the clutch basket you have to slide out the inner ring, otherwise it will not pass part of the case on the right. To slide out the inner ring I start to thread a dry wall screw into the hole and pull it out. It might take a few tries but it should slide out pretty easy.
7)Undo your shifter linkage off of the input shaft on the shifter side of the motor. Once it is off you should be able to pull the shifter rod out from the clutch side of the motor. WIth that out of the way you can see the shifting star and the ends of the rods holding your shifting forks. There is a small metal plate that is holding in the shift star/shift drum and the shift forks rod(don't remove the 2 bolts yet). Remove the oil pan from the bottom of the engine before removing any more from this side.
8) I had to lay my bike on it's side to get pics of the transmission from under. There is another rod with gears under the shifting drum you can't see.
9)Ok now remove the 2 hex heads holding in the shift star/shift drum and the shift forks. Slide out the rods and reach under the engine,try and keep a hand under the forks because they will drop out. With the front rod 1 fork will drop and with the rear rod 2 forks will drop out. Now inspect them.
Normal wear
My quick shifter killed the fork on the left. You can see it is shaved down really bad.
Install goes pretty easy just reverse it all and follow manual for all torque specs. I don't put in new gaskets everytime because my motor is taken apart too much. I clean the old one and all surfaces and use gasket maker from the parts store. It took me about 2 hours with taking pics to drop the forks out. To change out gears you will have to remove your WHOLE motor and split your case but with the shift drum and the shift forks out you can easily inspect all your gears for damage and see if they need to be replaced.
#101 ·
1st ger jumps.
I always hear about the 05-06 zx's jumping out of second but I've never heard of anyone having an issue like mine and I can't find any answers.
I have an 05 and it ONLY jumps in 1st gear. I think around the same rpm too (about 7k). I usually just shift before I hit it though. If I do hit it, I can decelerate and get on it again and not have it jump.
It doesn't jump out of gear. It just lurches forward. The guy I bought it from dropped it pretty hard on the left side, so does anyone think that replacing shift forks and drum would fix my problem?
#103 · (Edited)
After reading this I went outside and took her down the road, holding pressure on the Shifter. It's done this since I bought the bike and I've always just shifted early. I noticed however that it's starting to happen at different RPMs. it did it once at Eight, once at Eleven and once more somewhere along the range. The only thing that I noticed when I looked down was that my kickstand spring was pretty darn near toughing my lever. (the previous owner somehow bent my kickstand so it has a slight curve to it. I'm going to go outside and loosen everything up and see if I have full range on my shifter... if only I didn't let a buddy borrow my stands. lol
Thanks for the overlooked input. I'll let you know what happens.
One good thing came out of my ride today though... I got rid of my chicken strip :D
#105 ·
I know this thread hasnt been touched in almost 2 months, but I wanted to know if this is the same process to change the shift forks on a 05 zzr600? Ive asked 3 people and they all say the case has to be cracked. I'm capable of doing the shift forks if this is the same for the 05 zzr600. Thanks in advance.
#106 ·
Awesome thread, and a good read. Thanks for all the input from all the different folks who contributed.
I was just wondering if someone (in human terms) how all of these parts work together. I know we have gears, dogs, shift drums, shift stars, and shift forks. How exactly does the entire process work?
I'm just noticing that my shifting requires more effort lately, but I'm not having any issues with gears popping out or grinding. I've always shifted without the clutch, and it's always been smooth and properly revmatched. I have a 05 636.
#109 · (Edited)
Newbie
Brand new to the forum. 2000 ZX6R having some severe tranny issues. Was riding one day and all of the sudden she wouldn't downshift lower than 4th. Stopped the biked, checked her out and rode the shit out of the clutch to limp her home. Had only 4th &5th gears. No spring in the shifter, its either up in 5th, or down in 4th. Any ideas? About to tear her down and split the case just to see what I can see.
#112 ·
thank you for answer , i wish dogs will be ok .... will do this job in few weeks , or days . will write about it . it's just pop out in second some times , in neutral . that's it , on trackday it's ok , maybe because in racing gear shifting is more agressive . even if dogs will have some wear on it , is it possible to change just forks and drum , for solve this problem ????
#113 ·
One thing I have done to my bikes is flip the shifter to "GP" shifting. 1 up 5 down. I would hold my foot on the shifter for 2nd and 3rd gears. It was too late, the damage was done, but the few more times out on the track and street, it did help. My ZRX problem "WAS" caused because the shifter wasn't sticky from chain lube. Beat it up at Barber one year and found out that was the cause, not the gear box. Hard lesson learned on 2 bikes. I did buy the Star Shift Kit for both bikes when I repaired them. When you replace the drum and forks, take a picture in there if you can because I think I mentioned in post earlier, I think it's the middle fork, you can put it wrong and you won't be able to shift at all. Don't feel bad, I have to pop the head off my Camry again.....another burnt valve!!!!:mad::mad:
#115 ·
All, hello.
I'm on my second 2006 636, sold the first one for no good reason, other than to buy a Daytona 675 for the most part. My wife was going to keep the first one, but decided it was too much bike, so I sold it. Then I realized that I should always have a 636 in the garage, just because of the sheer comfort of it. It's literally the most comfy sport bike I've ever owned....then sold....then owned again, but I digress..
Bought this one, at a steep discount, because of an intermittent gear issue. Let's play...
Gears 1,2,3,4,5, and 6 all engage smoothly upshifting and also, with a throttle blip doing back down.
Gears 1,2,3,4,5, and 6 all stay engaged when the bike is ridden spiritedly.
However, gear number 3 and only 3, will slip when applying light throttle. "Cruising" amount of throttle, if you will. If accelerating briskly in 3rd, or blipping back down into 3rd, everything seems fine.
First thought is clutch. That's what it feels like when you intentionally slip the clutch, but only in 3rd gear? Nah, probably not right? So, using my mad googling and forum search skills, we're probably looking it shift fork(s), drum and/or gears, yes? Correct me if wrong, but if it were a fork or drum, it'd have a hard time going into gear, correct? And if it were worn dogs on the gear, it'd come out (slip) under hard or brisk throttle, but more likely to stay engaged during light throttle, yes?
Is my logic flawed? Obviously, the pan has to come off and first step is to inspect as much as I can without removing the engine, but I though I'd ping the braintrust here first. Seems like the majority of trans problems are the 2nd gear false neutral or 2/3 gear problems under hard acceleration. My issue the exact opposite..
Thoughts?
#116 ·
so , here is what i see , after chopeed my oil pan and clutch basket . what do you think ? i think it's worn hard ...also have inspect worn by manual and everything it's in change condition . have already order drum and 3 forks . on gears there is no problem i think . i can't turn it to see every of tooth , but seems that they are cool . hope i will works fine after i change this parts , that i order .
#118 ·
Normal wear
I know that its an old ppst but,i wass replace all 3 shift forks,shift forks rods,and shift drum,and now my bike shift only in first and neutral??bike is on stand and the rear wheel wass hand spened but ....
#121 ·
Normal wear
sorry to post on old forum, i have had my shift drum and forks replaced and still pops into neutral from first to second when shifting and feel my shifter almost bouncing on my foot.
Can someone point me in the right direction as to what gear dogs i need to order thank you guys
(Kawi to the world) :cool::cool:
