Ever since my "mini" crash on the freeway, my engine has been making a weird noise. I'm not a motorcycle expert, but the noise sounds like the pistons is scratching inside the cylinder walls, like friction on friction.
I thought it was my front brakes because it kind of sound like a braking noise, but when I pressed the front brakes while i was riding and while i was using the throttle, it still had that noise.
Unless i'm hearing things...
Is this normal? Is this happening to other peoples 08 Ninja 250r?
Also, there is a small leak around the valve cover, I think it is oil?
Thanks for reading and any help would be appreciated
