99 Kawi zx6r (G2) Build
9.7K views 10 replies 8 participants last post by  Ituen
#1 · (Edited)
First Off I’ll say Thanks for everyone that put the time and money in on finding out what could be used on the 98/99 zx6r.
I’ve keep a list of all the parts that I used my build on my 99 zx6r (G2)
The List:
98-99 UK Model ECU/CDI Box
02 zx6r Upper Cowl, Headlight, Air Rams and Grill
03-04 636 Forks, Fender and Lower Triple Clamp
05-06 636 Upper Triple Clamp
05-06 636 Front Axle with Spacers
05-06 636 Complete Rear Suspension (Gold Shock with Red Spring, Swing Arm, Axle, Brake Mount and Shock Linkage)
06 636 Special Edition Front and Rear Wheel with Rotors (No Rotor Spacers Needed)
06 zzr600 Upper Fairing Mount
06 zzr600 Cluster Gauge
07 zx14 Nissin Front Calipers
07 zx14 Rear Brake Line with line keeper
08 zx10r Front Caliper Bolts (73mm Long)
08 zx10 Front Master Cylinder and Clutch Mount
Other Make of Bikes:
07-08 Honda CBR 1000 RR Clip-on’s (see pic)
Custom Made Parts:
Solo Seat (see link)
4 Front Caliper Spacers
Swing Arm Exhaust Cover
1 Upper Triple Clamp Spacer
Steer Stops welded onto lower clamp
After Market Parts:
KerKer Can
Uni Air Filter
DynoJet Stage 1
Cycle Adjustable Levers
Zero Gravity Windscreen
Galfer Stainless Steel Front Brake Lines for the 03-04 636
The Links:
Parts List v2 - http://www.kawiforums.com/zzr600-zx-6r-old-school/158694-master-parts-swap-list-ver2-0-98-zx6r.html
Lever Controls - Cycle Control | Sportbike Products
How to make a Solo Seat - http://www.kawiforums.com/zzr600-zx-6r-old-school/83097-making-custom-solo-seat.html
Later this year will be the 07-08 zx6r Sub Frame & Tail Swap with under tail exhaust.
