no neutral light ??
4.7K views 5 replies 5 participants last post by  KawiRR
#1 ·
hi guy does any 1 know there the neutral senser is because my neutral light doesnt come on then its in neutral any ideas would be helpful
#2 · (Edited)
If you have the kickstand down and put it in gear, does the bike die? If so it's the light bulb or wiring. If it's in neutral and you put the kickstand down and the bike dies, then it's the sensor.
The actual neutral switch is behind the stator cover towards the bottom of the bike (RIGHT in front of the shift linkage)
#3 ·
the sensor should be right above the drive sprocket.. little green wire on it.. gound it to the case to test the light and the rest of the circuit.
#5 ·
thanks for the confirmation.
above.. below.. same difference.. lol
its got a green wire and is near the sprocket!!
