where to buy 2007 Kawasaki ninja 650 valve shims
1.3K views 1 reply 2 participants last post by  Antares
#1 ·
I've been looking on Amazon and see mostly Hot Cam shim kits for all but the Ninja 650. where's best to start looking for these shims or a compatable bike shim set. I only need a few since I can swap some out that are out of spec. i'd like to bring them all to the higher gap specs if those shims are available.
Thanks...
#2 ·
Thanks...
They are standard 7.48mm diameter shims, most modern kawis, suzukis, hondas and yamahas use that size, so anything will fit correctly. Sizes are generally 2.8-3.2 but depends on your specific bike. If you don't want to buy a kit (although they are only about 40-50 bucks for a kit that's enough for life (although there are also a lot of useless sizes) you can buy individual pieces from retailers like wemoto, although that's a UK retailer I'm sure there is a US equivalent, if not, I'm sure some independent bike shops would be happy to trade sizes for you, give them your old shims and they'll give you the size you need, might need to pay a little on top, but that's the cheapest way to go if you only need to replace 1 or 2 shims. Last resort, you can buy them directly from kawasaki but at 10 bucks a shim I'd not bother unless it's literally a singular shim you need to replace and juggling them around doesn't work.
