05 ZX6R gear box whine?
4.3K views 6 replies 6 participants last post by  spitz04
#1 ·
Hi guys had my bike for about 2 weeks now and have noticed that it whines a bit, maybe in the gear box, is this normal. My last few bikes have all been V-Twins (XB9R, TL1000s)
Not sure if its a broblem or just a normal thing that happens with them?
#2 ·
I can't help you out. For a while i was hearing a slight whistle sound at around 70-80mph. I couldn't figure it out. One day I whipped out my old 85 nighthawk and at 70-80 I noticed the same sound. Turned out that my helmet at the time had a vent that whistled slightly at that speed. kinda weird.
Save
#3 ·
When is this noise most pronounced?? I've always noticed a whine in my bike when in a high gear at a low speed,which i've always deemed normal.
Save
#4 ·
It seems to be normal. I notice it mostly in first/second/third when I roll off the throttle. It's also noticeable while accelerating gently, but it's not as loud.
It sounds like a straight-cut gear set in a car gearbox, which is about right because the gears in the bike gearbox are straight-cut. You just don't hear the noise on most bikes.
Save
#7 ·
"It sounds like a straight-cut gear set in a car gearbox, which is about right because the gears in the bike gearbox are straight-cut"
They are? Sure they arent helical?
Save
You have insufficient privileges to reply here.
