41 - 58 of 58 Posts
YEAR: 2009 black
INTAKE MODIFICATIONS:K&N snorkel removed
EXHAUST MODIFICATIONS: leo vince slip on, tuned for with and without baffle.
JET KIT OR STOCK? jet kit
BRAND OF JET KIT? Factory Pro
MAIN JET: 95 MJ, 140 pilot
NEEDLE AND CLIP POSITION: 2 clips from bottom
MIXTURE SCREW SETTINGS: 3 turns out
ELEVATION: 350 - 1800ft
MISCELLANEOUS INFORMATION ABOUT YOUR BIKE’S JETTING SETUP: Runs a lot better now, noticable difference, i can now go up a gear in some turns, with lower rpms and a little more torque.
Tuned using a dyno and sniffer, by Marietta Motorsports / BBC Racing. Will post results, later.
YEAR: 2008
INTAKE MODIFICATIONS: Airbox removed, Clean Air System Removed and Plugged, K&N R0990, Redline Breather (for the crankcase)
EXHAUST MODIFICATIONS: Full Yoshimura CF with silencer/low volume insert
JET KIT OR STOCK? Jet Kit
MAIN JET: 112
NEEDLE AND CLIP POSITION: 3rd Position (with 3 washers and cir-clip ONTOP to stop movement/bounce)
MIXTURE SCREW SETTINGS: 1.8 Out
ELEVATION: ??? 1000ft ??? Melbourne/Eastern Suburbs
Switched from FP 40 Pilot back to stock 38 Pilot (previously WAY to rich)...Bike pulls hard ALL the way to redline ! No surges, no bogging, no problems.Spark plug colour is 100% perfect.
YEAR: 2009
INTAKE MODIFICATIONS: Airbox removed... K&N 0990 filter and breather filter
EXHAUST MODIFICATIONS: PLMFG Full System
BRAND OF JET KIT? Factory Pro 3.0
MAIN JET: 112
NEEDLE AND CLIP POSITION: Clip on the 3rd position with 3 washers above it. (per FP instructions)
MIXTURE SCREW SETTINGS: 2.5 turns on both sides
ELEVATION: Sea Level
Bike feels a lot more responsive, and pulls through redline. Need to ride more to get a better feel of it. A lot of popping from the exhaust.
YEAR: 2008 black
INTAKE MODIFICATIONS: 2" diameter muffler pipe extensions to simulate factory runners, (2)UNI POD clamp on dual layer filter UP6200ST 2"x6"
EXHAUST MODIFICATIONS: Factory
MAIN JET: 110
NEEDLE AND CLIP POSITION: 3rd clip down from top
MIXTURE SCREW SETTINGS: 2.5 turns out
ELEVATION: +20
MISCELLANEOUS INFORMATION ABOUT YOUR BIKE’S JETTING SETUP: Relocated the main fuse/solenoid assembly from starter to battery to a new position since the 6" filters with stacks need exactly all the way to battery box. It sounds awesome as can be and is running very strong all around at these settings, I notice it pulls to redline much stronger than before but I am still going to try the 112 jet and see if it gets more.
YEAR: 2010
INTAKE MODIFICATIONS: Air box eliminated, K&N R 0990, K & N Crankcase Breather
EXHAUST MODIFICATIONS: Full Yoshimura System with silencer insert
JET KIT OR STOCK? Kit
BRAND OF JET KIT? Factory Pro 3.0 Configuration
MAIN JET: 112 (Factory Pro/Keihin)
PILOT JET: 38 (Stock)
MIXTURE SCREW SETTINGS: 2.5 Out
Much improved over stock. Pulls strong from 3k to 13 K, idles well and fires up on the first rotation of crank. Initially had Idle mix screw at 3.0 out, and ran well, etc,., but seemed some what rich off idle at low speeds. Set to 2.5 out now; seems crisper throttle response, and better low speed pull. Dropped needles from 3rd to 2nd, too lean, kept at 3rd.
YEAR: 2009 SE
INTAKE MODIFICATIONS: K&N filter, snorkel removed
EXHAUST MODIFICATIONS: Full Jardine GP1 system
BRAND OF JET KIT? DynoJet
MAIN JET: 98
NEEDLE AND CLIP POSITION: 3rd space with 2 washers
ELEVATION: ~700
I bought it used 100% Stock and it would not run cold at the time I went to buy it, owner "Warmed it up" for about 10 minutes and it still ran rough down low (under 3000) very very sluggish throttle response.
The ambient temp was only about 30 degrees F. After installing the jet kit, full exhaust,K&N filter, and removing snorkel the bike runs top notch! while tuning and syncing carbs I kept the garage about 55 deg. F and I can see it runs a touch lean, but will wait for spring to give it a final tweek.
YEAR: 2010
INTAKE MODIFICATIONS: Air box eliminated, K&N R 0990, Crankcase Breather
EXHAUST MODIFICATIONS: TB S/O
MAIN JET: 110 (Factory Pro/Keihin)
NEEDLE AND CLIP POSITION: 3rd Position, 3 washers above with clip per directions
ELEVATION: 600ft
YEAR: 2009
INTAKE MODIFICATIONS: Kleen Air removal, Air-box removed, K&N R-0990, Crankcase breather.
EXHAUST MODIFICATIONS: PLMFG Power Driven Full Exhaust.
BRAND OF JET KIT? Dyno Jet with Keihin mains
MAIN JET: 112
NEEDLE AND CLIP POSITION: 3rd from top, 2 washers underneath
MIXTURE SCREW SETTINGS: I believe there both @ 3 turns out
ELEVATION: California approx 233
Holy piss where do I begin. So everyone who says the air-box is a real p.i.t.a to remove, there not lying. took me and a friend a long time to disassemble the bike to squeeze it out haha. I'll try to attach a pic. I recommend having a friend help out if your not mechanically inclined (like me lol). Once it was out the carbs are soooo much easier to get to. Definitely worth the trouble. We had so much trouble starting the bike afterwards, (found out it was just the e.c.u not plugged in DOH :Laughing rolling: ) that I couldn't test out the 100 main that i got in the dyno kit. But in the end settled with 112 main, 3rd clip position with 2 washers, and 3 turns out on the mixture screws. Bike seems to love that set-up, low-end is about the same but mid to high revs are really fun. It's a whole new bike. And boy does she roar. I set off about 2-3 car alarms for the first time the other day as I drove by them. Felt pretty good :cool: Still have to sync the carbs and may try other settings but for now, I really like this set-up and recommend it to people who are going down my direction. :)
YEAR: 2010 SE
INTAKE MODIFICATIONS: KN Filter, non-pod
EXHAUST MODIFICATIONS: None
JET KIT OR STOCK? DJ
BRAND OF JET KIT? Leftover DJ Mains
MAIN JET: DJ98
NEEDLE AND CLIP POSITION: Stock Needles, 1 Washer
MIXTURE SCREW SETTINGS: I'd say 2.6
ELEVATION: Los Angeles, Orange County, Long Beach = Misc
MISCELLANEOUS INFORMATION ABOUT YOUR BIKE’S JETTING SETUP: I've removed the CA emissions, added the fuel filter to the gas tank. Idle is at 1.5k. I probably need to raise the idle mixture screws, but for about $15 including carb sync this setup can't be beat. Bike pulls way better than stock and is a blast to ride.
Also, I originally bought some "Keihin" 100's that were actually brand AB 100. These were a bit rich and I like the DJ98's, which I scavenged from ForeverBlake, a lot.
EDIT: Also I have a bit of popping from my exhaust, nothing really bad just barely noticeable, should I remove the Kleen Air lines/Resync carbs?
YEAR: 2008
INTAKE MODIFICATIONS: K&N R-0990
EXHAUST MODIFICATIONS: None (Getting yoshi full)
JET KIT OR STOCK? Factory Pro
MAIN JET: 112
NEEDLE AND CLIP POSITION: 3rd from top with 2 washers underneath
MIXTURE SCREW SETTINGS: 2 3/4 turns
ELEVATION: sea level to 350ft (1000+ very now and then)
Basically copied Vex's as I'm sure it would be fairly close...and it runs really good...won't mess with it til the full exhaust comes in.
YEAR: 2009
INTAKE MODIFICATIONS: Dual UNI UP4200AST pods, Clean Air removed, uni UP122 breather on order for crankcase breather.
EXHAUST MODIFICATIONS: Custom stocker gutted and made straight-through glass-pack using exhaust pipe from wrecked 250r (for consistent diameter).
JET KIT OR STOCK? Stock
BRAND OF JET KIT? N/A
MAIN JET: EBC 112.5 (same as Keihin 112.5)
NEEDLE AND CLIP POSITION: Stock needles w/ 3 washers
MIXTURE SCREW SETTINGS: ~2 turns
ELEVATION: under 1,000 ft.
MISCELLANEOUS INFORMATION ABOUT YOUR BIKE’S JETTING SETUP: Ran it with custom exhaust and snorkel removal and 110 Keihin main jet with 1 needle washer and it would lean out at 80mph WOT. Decided to go pod filters before tearing back in and WHAM! I have to watch out for redline like never before. Now plugs are light brown and it runs, sounds, and pulls amazing!
YEAR: 2009
INTAKE MODIFICATIONS: K&N Pods w/ stock runners, kleen air deleted and blocked
EXHAUST MODIFICATIONS: PLMFG Full Exhaust
JET KIT OR STOCK? Jets only from Jets R' Us
BRAND OF JET KIT? Jets R' Us
MAIN JET: 112
PILOT JET: stock. 38 I think.
NEEDLE AND CLIP POSITION: 3 #4 washers under each needle (stock)
ELEVATION: 800ish I think. Minneapolis, MN
MISCELLANESOUS INFORMATION ABOUT YOUR BIKE’S JETTING SETUP:
I did all my engine mods yesterday at the same time, save for shimming 2 washers last year. I decided to take the bike to school 60mi each way to see how it runs through the entire range. At first I had the screws at 2 1/2 out but the tach was all over the place with trouble keeping it running when cold before leaving this morning. Turned them out another quarter after I got home from school today, and it started right up with a steady RPM. I also pulled the plugs to see if I was too lean/rich, they looked to be about the perfect color. Figured a 60mi ride with a final WOT once I got in the garage would give me an accurate read (pic posted below).
In regards to performance difference. I love it, the exhaust has a nice deep tone with a little burble on deccel, and I had mild power wheelie on a 1-2 shift. Being that my bike is fightered the airbox delete also adds a lot to the bike visually.
YEAR: 2011
INTAKE MODIFICATIONS: Air box removed >> K&N Open filter, Kleen air system removed
EXHAUST MODIFICATIONS: Jardine RT-5 Full exhaust System
JET KIT : Factory Pro Stage 3
BRAND OF JET KIT : Factory Pro
MAIN JET: 112
PILOT JET : 40
NEEDLE AND CLIP POSITION: # 3rd, with 2 washer above and 1 washer underneath
MIXTURE SCREW SETTINGS : 2.5 turn out
The Bike running well, feels much quicker and rips through the midrange and pulls all the way to redline with no problems. The powerband is much smoother now and definitly is more responsive.
It may not be perfect,yet... In progress try to switch needle & clip position at #3rd with 2 washer underneath and set the mixture screw 2.75 turn out or more
Lachcik's 2012 Ninja 250R
YEAR: 2012
INTAKE MODIFICATIONS: Removed Kleen Air System & Airbox
EXHAUST MODIFICATIONS: DanMoto Custom Exhaust w/High Degree Flat Black Paint
BRAND OF JET KIT? Factory Pro Stage 3 JetKit
MAIN JET: 112
NEEDLE AND CLIP POSITION: Needle, 3 washers and clipped at 3rd position
MIXTURE SCREW SETTINGS: Factory Setting on Right Carb, about 2 out on Left Carb
ELEVATION: I'm in El Paso so low I'm guessing
MISCELLANEOUS INFORMATION ABOUT YOUR BIKE’S JETTING SETUP: Pulled out the Kleen Air System, threw on the PN-0990 K&N Pod Filter, K&N Breather on the crankcase. Took me forever to figure out how a carbureted bike works, but within one weekend I got very familiar and consider myself a pro at taking this thing apart :)
YEAR: 2011
MAIN JET: 112
PILOT JET : 40
ive got pretty much the same exact setup. i put 3 washers under the needle with the clip being at the 3rd position and adjusted the fuel mixture screws until i got good throttle without it dying in power after letting off the throttle. i guess it was a big rich until i did some adjustments.
YEAR: 2012
INTAKE MODIFICATIONS: Snorkel removed + intake widened to double size + K&N filter.
EXHAUST MODIFICATIONS: Musarri Muffler
JET KIT : Factory Pro Stage 1
MAIN JET: 100
PILOT JET : 40
NEEDLE AND CLIP POSITION: # 4th, with 3 shims half throttle
STOCK POWER: 24.69hp
POWER AFTER JETTING: 26.65hp
YEAR: 2009 250R
INTAKE MODIFICATIONS: Air box removed k&n r-0990
EXHAUST MODIFICATIONS: Yoshimura Full CF exhaust
JET KIT OR STOCK? Jetted
MAIN JET: DJ108
NEEDLE AND CLIP POSITION: Eclip on 3nd position, with two washers underneath.
MIXTURE SCREW SETTINGS: each 2.5 turns out
ELEVATION:0ft to knee high
MISCELLANEOUS INFORMATION ABOUT YOUR BIKE’S JETTING SETUP: Seems to be running well. Pulls good through the rev range. I don't feel any dead spots. Ill check the plugs and if they are fine ill leave it be
__
Did this work good Long term?
41 - 58 of 58 Posts
