So I have my entire bike torn apart and my engine had been running a bit sluggish so I checked my valve clearances. On three of my exhaust valves the clearances were less than the suggested. (Supposed to be .22 to .31 mm. I measured two at .2 and another at .15) I looked at the shims used by the manufacturer and found that they put in a 3 mm shim, a 2.9 mm shim, and a 2.95 mm shim.
My curiosity has me asking why did the clearance on these three valves get under the range they should be? I can understand if they had too big of a gap. Any ideas?
P.S. All the other valve clearances were in range for exhaust the intake. It was only these three valves that were off.
