Ok, so I took off work today to check the vavles on my 02 zx-6r with 8000 miles. Valves check was alittle overdue.
Anyhow literally all but 6 valves seem too tight. I'm pretty sure I'm checking them right. and the 6 vavles that aren't too tight are on the tight side of tolerance.
How tight should the feeler guage feel. Should it slight in or should there be a good bit of resistance?
All my exhaust valves seem tight except for one. Is this common for the exhuast valves to tighten up?
anyhow, I guess I need shims right? So should iI shim them on the loose side of the tolerance to be safe? Will I loose much power doing this?
Also my valves did seem to be tapping or something, would tight valves cause this noise?
my poor bike....
My Kawasaki manual says inlet valves need to be between .11 - .19
and exhuast valves need to be between .22 - .31
and as you can see from the details below, I'm right on the tight side of everything...which make me alittle worried.
p.s. don't make fun of my photoshop skills
my poor bike....
