21 - 40 of 534 Posts
Discussion starter · #21 ·
Nice work!
If it's not of hard work, I wish you'll save the code that does not heal the speedo. As 03/04 and 07/08 kawis use same speedo input no healing is needed.
And I'm just throwing this: if you run other gearing than stock but catch the rpm and speed input (speedo will be off) won't it calculate the gear right? And if you would use something like a speedohealer AFTER the gear has been calculated, you would also have correct speed on the speedo? So that would address the problem with gearind changes...
Hi markketo.
I've had a look at the service manual for the 03/04 model and it looks like the speedo signal is completely different to the P7 (though the data on the P7 is also wrong in my copy):
03/04 speedo : 60mph @ 146Hz engine signal
04/05 speedo : 60mph @ 1168Hz engine signal
06/07 speedo : 60mph @ 276Hz engine signal (service manual says 840Hz)
I'm working in Miles rather than Km but the difference remains.
In addition the book says 3rd gear is a different ratio between 03/04 and 05/06. Am fairly certain the new model is very different gearing to either old bikes.
Have already mentioned that the final drive gearing is not an issue.
The 05/06 bikes use a dedicated FI line from the ECU to the speedo. Since this is also present on the P7 clocks then I'm assuming the normal FI error codes will still be reported correctly. Have to check this of course!
Extr400
i understand this a little bit you and you are doing a hell of a job keep it up man, its a lot of hard work i wish i had the time in the day to do this stuff and all that
I would like to be the first person to point out that I have no idea what any of this shit that you're talking about means.
But if it lets people with a 636 get an analog tach, then right on brother :)
At least both 03/04 and 05/06 use the same method for displaying error codes - i.e. blinking the led for certain amounts and times. So if the FI works for the 05 it should work on the 03 too. I'm trusting you on this one, I'm pretty impressed on your electrical skills.
The gear information is going trough that dedicated FI signal (ecu communication pulse on 07, FI indicator light ground for 03-06) so I think it has to have some kind of interrupting pin. I've understood you're taking the ecu signal into the box anyway so it can't be that hard to code?
Another thing is what the box does while the clutch is in? If it doesn't send, won't it give the FI light then? I'd like it to stay showing the previos gear before it detects a new one, I believe that can be programmed? Or is there a way to send a blank gear other than neutral light?
The factory tacho should have around 7-10% error in it, I'm pretty amazed if the 07 item has only 2,5% error. Or it may even feed the tacho a bit optimistic signal to get around that 7% error. 16500 real rpm sounds way high for the engine to take. 03 has a gauge redline of 15500 and real engine redline of 14700 or something.
damn and i am thinkign of going to the kit gauge right and selling my 07 gauge set-up..
might hold off now.
For the redline thing, my 07 tach was off at about 600RPm on top while on the dyno with the 05 bike.
Discussion starter · #32 ·
Been away on a surf trip (no motorbikes involved) to not so sunny but very wet north west Ireland. After a week of throwing myself in cold sea water, am now back on the case.
Have been looking at correcting the tacho signal in the same way as the speed signal. Trouble is the resources are at a max inside the little pic micro. I suppose I could just use two micro's but that wouldn't be very elegant. At the moment I'm going to just punt the same tacho pulses back out on a different pin on my chip. Maybe I can find a solution at a later date and post a software update to fix it.
Have also been looking into connectors to allow a plug and play solution for this project. The ZX6 LCD clocks use a 16 pin AMP connector but I can't find the part number on the Tyco Electronics website. The new analog tach clock uses a JAE 20 pin part (the harness side part number is MX34020SF1). The connector shells are quite cheap but I have to buy the crimp pins on a whole reel of 7000 which cost a fortune. Anyone know of a supplier for these selling just a few hundred, please send me a message. There may be a way around this problem by making the PCB be the connector shell. I'll post pictures of what I mean in due course.
Am just tuning up the software so the gear display is good for any gear/speed. I'll post a list of components/part numbers, the circuit diagram and the basic software in a week or so.
Anyone interested in buying a plug and play solution, please mention it on this post. It will give me some idea of what kit of parts to buy in. I would expect to sell built up and tested adapters for around $40 if your not up for building one yourself (most of the expense is in getting a circuit board manufactured and the cost of connectors).
More soon.
Extr400
if you need a 20 pin harness i have one sitting here with pigtails.
But yeah i am interested in one that will get the damn fuel light to stop blinking, and of course the gear indicator would be awesome as well.
I am game for anything you need help with, just let me know...so will a speedohealer still be needed?
