2008+ Ninja 250 Mod/DIY/FAQ : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 04-30-2008, 09:13 PM   #1 (permalink)
2008ninja250r's Avatar
2008ninja250r has at least 500 rep points2008ninja250r has at least 500 rep points2008ninja250r has at least 500 rep points2008ninja250r has at least 500 rep points2008ninja250r has at least 500 rep points2008ninja250r has at least 500 rep points2008ninja250r has at least 500 rep points
Default 2008+ Ninja 250 Mod/DIY/FAQ
Here is a compilation of DIY threads for the 2008+ Ninja 250r. If you see a thread that you think should be included in here please post it up and/or pm me. The same goes for any dead/missing links.
General
Buying Used:
Buying a used 2008/09 Ninja 250R - What should I look for/Advice/Common Issues?
Basics
Thread with Parts Diagram link
this site shows how to asseble entire bike bolt by bolt : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: Lifting the Bike with Stands
Lifting the 250R : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Maintenence
Maintenence Spread Sheet:
http://www.kawiforums.com/ninja-250r...readsheet.html
DIY: Oil Change
2008 Ninja 250 Oil Change Procedures : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: Lubing and Adjusting the Clutch Cable
DIY- How to Lube and Adjust the 250R Clutch Cable and How to Add 10 HP w/ one Mod!!! : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
The ULTIMATE 250r Winterization thread:
Winter storage? (THE Winterization question/answer thread for 250's)
DIY: Checking valve lash
DIY - Checking valve lash on '08+ 250r (WITH pictures) : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: Adjusting Valves
DIY - Adjusting Valves on '08+ 250r (WITH Pictures) : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Bodywork
DIY: Fairing Removal
Let's Get Nekkid!!! : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: Removing the Gas Tank
How to Remove the Gas Tank : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Carburetor and Jetting
Note: "Be very careful when you're dealing with the slides as the diaphram will tear if you're not careful and they are around $100 each!"
Jetting Database
250R Jetting Database : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Jetting Database Discussion
Jetting database discussion : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
How To: Remove Carburetors in under 10 minutes (video)!
Howto: Remove carbs in under 10 mins [Video!]
DIY: Raising the Needle Jets
Raising the Needle Jets..Mod. : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: JetKit Install and Re-jet
DIY JetKit install/re-jet : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: Changing the Main Jets With Carbs Still on Bike
DIY/How-To on changing Main Jets without removing the carbs! : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: Carb Syncing
Carb sync'ing the '08 250 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: Drilling the Carburetor Slides
DIY - Drilling the carburetor slides : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Airbox/Hoses and Fuel System
DIY: Gas Tank Noise Elimination
gas tank noise elimination mod with pictures : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: Intake Snorkel Removal
DIY- Removing the Snorkel : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: Removing the Factory Airbox: Installing an Aftermarket Air Filter
Removing the factory air box: Installing an aftermarket air filter : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: Removing the Kleen Air System Hoses and Plugging the Holes
DIY- Removing the Kleen Air System Hoses and Plugging the Holes on a 08 250R : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Exhaust
2008 250r Exhaust
2008 250r exhaust options (Lots of Vids)
DIY: 06-07 GSXR Exhaust Fabrication/Install
DIY: 06-07 GSXR Exhaust install for 08 Ninja 250 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: AreaP "Quiet Core" SS Exhaust Install
AreaP "quiet core" SS Exhaust Install : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Brakes
DIY: How to Replace Brakes Pads in 10 minutes [Video!]
[VIDEO HOWTO]: Replace Ninja 250 Brake Pads in 10 mins
DIY: Installing a ZX-6R Master Cylinder
DIY - Installing a ZX-6R Master Cylinder on an '08+ 250r : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: Moving the Rear Brake Reservoir
DIY - Moving the rear brake reservoir : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Seats and Luggage
Semi-DIY: Seat Shaving Mod
08 Ninja 250 Seat Mod : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: Corbin seat install
Corbin seat install : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: Custom Seat Creations Seat Covers Install
Custom Seat Creations Seat Covers DIY Install : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Semi-DIY: Rear Seat Hard Luggage Mod
Givi Look alike trunk Mod : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Frame and Suspension
MOD: Vortex Clip-ons Installed
Vortex Clipons On!!! More to come as parts come in
DIY: SV650 Clip-Ons
Ladies & Gents. I give you..........Clipons!
DIY: Install Intuitive Frame Sliders
DIY: Install Intuitive Frame Sliders : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: Shogun No-cut Crash Kit
Shogun no cut crash kit installation
DIY: Installing RPM Steering Damper
DIY Ninja 250R - RPM steering damper.
DIY: Installing a Front Lowering Kit
Installing a front lowering kit : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: Using the Passenger Pegs as Front Pegs
DIY Using the Passenger Pegs as Front Pegs : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Fender Chop Master Thread
Post your 2008 250 Fender Chops : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: Targa "No Cut" Fender Eliminator
Targa "No Cut" Fender Eliminator DIY : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: Ebay Tire Hugger Install
How to Install the Ebay Tire Hugger : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
A-tech rear hugger
A-tech rear hugger on 2010 Ninja 250
2008ninja250r is offline   Reply With Quote
Old 04-30-2008, 09:36 PM   #2 (permalink)
Hello Mate!
snatch has at least 1500 rep pointssnatch has at least 1500 rep pointssnatch has at least 1500 rep pointssnatch has at least 1500 rep pointssnatch has at least 1500 rep pointssnatch has at least 1500 rep pointssnatch has at least 1500 rep pointssnatch has at least 1500 rep pointssnatch has at least 1500 rep pointssnatch has at least 1500 rep pointssnatch has at least 1500 rep points
(Due to 2008Ninja250r's post running too long I'm having it run over into Snatch's post) - VeX
Wheel and Tire
DIY: Changing Tires
DIY- Changing Tires on the 250R : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: Polished Wheel Lip Mod
Polishing your rim's : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Chain/Sprocket
DIY Video - Replacing chain and sprockets
http://www.kawiforums.com/ninja-250r...ts-10-mins.htm
Semi-DIY: Sprocket Swap
Sprocket Swap ... with pictures : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
15 T Front Sprocket (not a DIY but it has good info)
15 tooth frt sprocket : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Electrical and Lighting
2008+ Full Wiring Diagram
2008+ FULL Wiring Diagram here!
DIY: XLS LED Lights
DIY: XLS LED lights : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
DIY: Installing LED gauge lights
LED gauge bulb replacement
Semi-DIY: 12V Socket Install
Semi-DIY: 12VDC Socket Install : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Moty Design Battery
Moty Design Batteries for Ninja250R & others: No power loss here!
Other Mods
Homemade Camera Mount
Home Made Camera Mount - Page 2 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
AFTERMARKET PARTS
2008 Ninja 250R - Aftermarket Parts/Accessories
A-TECH STYLE CARBON FIBER HUGGER
a-tech style carbon fiber hugger thread
I will see about having this stickied.
2008 Kawasaki Ninja 250R
snatch is offline   Reply With Quote
Old 04-30-2008, 10:53 PM   #3 (permalink)
MurderedOut's Avatar
MurderedOut has at least 250 rep pointsMurderedOut has at least 250 rep pointsMurderedOut has at least 250 rep points
Good Job
MurderedOut is offline   Reply With Quote
Old 04-30-2008, 10:56 PM   #4 (permalink)
kkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep points
great idea... rep for you!
kkim is offline   Reply With Quote
Old 04-30-2008, 10:59 PM   #5 (permalink)
Lloyd574's Avatar
Lloyd574 has at least 50 rep pointsLloyd574 has at least 50 rep points
The front seat mod is one of my favorites..I could not ride the bike on the stock seat more than 20 miles..
Lloyd574 is offline   Reply With Quote
Old 04-30-2008, 11:04 PM   #6 (permalink)
Damn Lloyd... at least provide the boy with a link!
I do admit, that does look like a great DIY.
Old 05-01-2008, 12:04 AM   #7 (permalink)
Jrm
Jrm's Avatar
Jrm has at least 50 rep points
I approve of this thread.
Jrm is offline   Reply With Quote
Old 05-01-2008, 12:06 AM   #8 (permalink)
Datkush's Avatar
Datkush has at least 500 rep pointsDatkush has at least 500 rep pointsDatkush has at least 500 rep pointsDatkush has at least 500 rep pointsDatkush has at least 500 rep pointsDatkush has at least 500 rep pointsDatkush has at least 500 rep points
i think what we need is a tutorial on how to search and what not to post for all new members of the 250 forum before they are allowed to sign up
Datkush is offline   Reply With Quote
Old 05-01-2008, 12:19 AM   #9 (permalink)
Swiss's Avatar
Swiss has at least 10 rep points
I tried this thread a few weeks ago and it was shut down on the pre tense that there is already a DIY ( How to's and FAQ's) forum. My argument was that it is fraught with pandemonium and chaos with all the various models and it would make more sense to have a DIY thread in each specific model froum instead of a froum for all models' DIY's
250R DIY Thread
Swiss is offline   Reply With Quote
Old 05-01-2008, 12:24 AM   #10 (permalink)
TheDuck's Avatar
TheDuck has between 7,500 and 10,000 rep pointsTheDuck has between 7,500 and 10,000 rep pointsTheDuck has between 7,500 and 10,000 rep pointsTheDuck has between 7,500 and 10,000 rep pointsTheDuck has between 7,500 and 10,000 rep pointsTheDuck has between 7,500 and 10,000 rep pointsTheDuck has between 7,500 and 10,000 rep pointsTheDuck has between 7,500 and 10,000 rep pointsTheDuck has between 7,500 and 10,000 rep pointsTheDuck has between 7,500 and 10,000 rep pointsTheDuck has between 7,500 and 10,000 rep points
I could barely ride it for 20 seconds before my ass hurt, I don't know how you made it 20 miles!
TheDuck is offline   Reply With Quote
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
